Basket
TopicsRepliesAuthorViewsLast Posts
No new posts  Announcement:  PAS3 preamp upgrades & modifications 1tubes4hifi7052View latest post on Fri Jun 30, 2017 12:43 am
by erhard-audio
No new posts   Canadian company has acquired the "Dynaco" trade name ? 1, 2, 370Bob Latino7122View latest post on Wed Feb 06, 2019 9:54 pm
by ltusler
No new posts   New VTA ST-120 1ImFritz328View latest post on Wed Feb 06, 2019 12:16 am
by Dogstar
No new posts   Dynaco MKII Troubleshooting 22drafalske552View latest post on Tue Feb 05, 2019 9:58 am
by drafalske
No new posts   Reccomendations for a Diy Dac 9ImFritz563View latest post on Tue Feb 05, 2019 9:17 am
by cci1492
No new posts   SP14 mechanical hum.  7FearOfMusic360View latest post on Mon Feb 04, 2019 4:34 pm
by FearOfMusic
No new posts   Auto-bias board and a Weber WS1 23Kramer1337View latest post on Mon Feb 04, 2019 5:38 am
by jsl1234
No new posts   Pic test with Max 6ImFritz264View latest post on Sat Feb 02, 2019 5:30 pm
by ImFritz
No new posts   Ok ok ok I think Ive got this 0ImFritz487View latest post on Sat Feb 02, 2019 7:57 am
by ImFritz
No new posts   ST-120. Which tap for which configuration. 1bbqjoe188View latest post on Fri Feb 01, 2019 8:01 am
by Peter W.
No new posts   SCA-35 Front Panel Wiring Pictorial 3stewdan139View latest post on Thu Jan 31, 2019 5:36 pm
by stewdan
No new posts   Turn on and turn off procedure 8ImFritz283View latest post on Thu Jan 31, 2019 9:23 am
by Peter W.
No new posts   ANK DAC 4.1 Build 1, 2, 360cci14921970View latest post on Tue Jan 29, 2019 6:28 pm
by bbqjoe
No new posts   Info or circuit diagrams on Melos modded Dynaco MK 4 18miniaussie417View latest post on Tue Jan 29, 2019 2:00 pm
by Peter W.
No new posts   Desoldering station recommendations? 14vtshopdog739View latest post on Sat Jan 26, 2019 4:03 pm
by BNR_1
No new posts   New Member 12Cav Trooper638View latest post on Sat Jan 26, 2019 12:10 pm
by Cav Trooper
No new posts   Subwoofer tube amplifier? 2bbqjoe233View latest post on Fri Jan 25, 2019 4:00 am
by pichacker
No new posts   Statistics 18Dogstar500View latest post on Thu Jan 24, 2019 3:24 pm
by bbqjoe
No new posts   Serious Red Plate event 15CletusB771View latest post on Thu Jan 24, 2019 12:25 am
by bbqjoe
No new posts   PH-16 Tube rectifier vs diode mod 3mdelrossi291View latest post on Wed Jan 23, 2019 7:25 pm
by tubes4hifi
No new posts   ST-70 driver board cover installation shortcut 7fmorelli333View latest post on Mon Jan 21, 2019 1:38 pm
by Peter W.
No new posts   The SP14, mechanical isolation and you. 10bbqjoe332View latest post on Sun Jan 20, 2019 2:25 pm
by bbqjoe
No new posts   ST120 Quad Cap Voltage Rating 2mazeeff179View latest post on Fri Jan 18, 2019 1:37 pm
by mazeeff
No new posts   Psvane KT-88's 1mhardyman231View latest post on Thu Jan 17, 2019 5:51 pm
by peterh
No new posts   SP14. Has anyone got a solid pic of the AC, fuse and terminal wiring? Help please. 13bbqjoe476View latest post on Thu Jan 17, 2019 4:44 pm
by Jedidiah
No new posts   SCA-35 Selector Switch 24Tom_Johnson753View latest post on Thu Jan 17, 2019 3:23 pm
by Tom_Johnson
No new posts   Question for Bob 16eickmewg679View latest post on Wed Jan 16, 2019 4:21 pm
by bbqjoe
No new posts   Adding meters to a SP14.  7FearOfMusic379View latest post on Mon Jan 14, 2019 1:23 pm
by Peter W.
No new posts   Starting first restore 1, 247ttownscott2271View latest post on Sun Jan 13, 2019 11:40 pm
by PeterCapo
No new posts   Balanced power 9FearOfMusic304View latest post on Sun Jan 13, 2019 6:35 pm
by peterh
No new posts   ST70 with new VTA Board (12AU7) upgrade question/problem? 3tgrier408View latest post on Sat Jan 12, 2019 2:24 pm
by tgrier
No new posts   ST-70 6B4G 6ronton3340View latest post on Sat Jan 12, 2019 2:04 am
by ronton3
No new posts   Issues with M125 after Auto Bias install 1, 247Skydogcable2124View latest post on Fri Jan 11, 2019 6:25 pm
by tubes4hifi
No new posts   PH16XW NoiseFloor/Hum 1, 228Skydogcable1282View latest post on Fri Jan 11, 2019 2:45 pm
by tubes4hifi
No new posts   Bucking Transformer 4Peter W.272View latest post on Thu Jan 10, 2019 11:28 am
by cci1492
No new posts   Need help with auto bias board malfunction 1, 235kevinmi1999View latest post on Thu Jan 10, 2019 3:57 am
by pichacker
No new posts   SP10 preamp reviews? anyone have one? 5demarko69319View latest post on Wed Jan 09, 2019 7:57 pm
by demarko69
No new posts   5V AC Filiment Voltage On Amp With Solid State Rectifier 7mazeeff195View latest post on Wed Jan 09, 2019 1:26 pm
by erhard-audio
No new posts   Purpose of chokes 11wildiowa460View latest post on Tue Jan 08, 2019 2:51 pm
by DarthBubba
No new posts   Is there a 12VDC source on the ST-120 24bbqjoe319View latest post on Tue Jan 08, 2019 1:45 pm
by aguaazul
No new posts   ST120 completed 17mikescaggs441View latest post on Tue Jan 08, 2019 2:55 am
by bbqjoe
No new posts   Experience with Maggies or other planar (including ML electrostatics). 21jsl1234820View latest post on Mon Jan 07, 2019 11:08 pm
by jsl1234
No new posts   122v and above - why not address the issue? 22dalemurray658View latest post on Mon Jan 07, 2019 11:24 am
by cci1492
No new posts   VTA ST-120 Speaker problem - solved ! 10sandeep dutta575View latest post on Sat Jan 05, 2019 1:27 pm
by sandeep dutta
No new posts   Dynaco MKIII high B+ 5U4 low bias 2ronton3177View latest post on Sat Jan 05, 2019 9:46 am
by ronton3
No new posts   Help with ST-120 custom build 0ureche189View latest post on Fri Jan 04, 2019 5:23 pm
by ureche
No new posts   How to verify the input load impedance on a phono pre 22Skydogcable413View latest post on Mon Dec 31, 2018 7:01 pm
by erhard-audio
No new posts   Merry Christmas to All 1ggnarley151View latest post on Mon Dec 31, 2018 6:21 pm
by Tube Nube
No new posts   6AN8 Revisited 3Wilhelm268View latest post on Sat Dec 29, 2018 12:44 pm
by Wilhelm
No new posts   VTA120 - bass no longer present - fixed ! 6fmorelli495View latest post on Thu Dec 27, 2018 9:15 pm
by fmorelli
No new posts   Can we fix all these red links on Wikipedia? 3bennytehcat216View latest post on Thu Dec 27, 2018 2:36 pm
by deepee99
Moderators
None
Permissions in this forum:
You cannot post new topics in this forum
You cannot reply to topics in this forum
Users browsing this forum: 2 Registered, 0 Hidden and 3 Guests
Registered Users: peterh, wgallupe
  • New posts New posts
  • No new posts No new posts
  • New posts [ Popular ] New posts [ Popular ]
  • No new posts [ Popular ] No new posts [ Popular ]
  • New posts [ Locked ] New posts [ Locked ]
  • No new posts [ Locked ] No new posts [ Locked ]
  • Announcement Announcement
  • Sticky Sticky
  • Global announcement Global announcement
Current date/time is Sat Mar 23, 2019 3:36 am
