Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 3888 | Sat Dec 02, 2023 5:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 799 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1288 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
Red plating | 23 | mhardyman | 5184 | Sun May 26, 2019 8:27 pm by Pat R. | ||
KT120 and 5AR4 combination on VTA ST120 | 7 | rodulfo23 | 1383 | Sat May 25, 2019 10:15 pm by ImFritz | ||
Music media sales 1973 - 2017 > Chart | 0 | Bob Latino | 482 | Fri May 24, 2019 8:56 pm by Bob Latino | ||
VTA ST70 Auto Bias Hum 1, 2 | 46 | breading | 3939 | Sun May 19, 2019 1:54 pm by Kramer | ||
6GB8 tube - an upscale EL34 | 3 | howlin' hoosier | 2460 | Sun May 19, 2019 1:02 pm by howlin' hoosier | ||
How much additional noise is normal when adding a phono stage to a preamp? | 21 | rjpjnk | 2039 | Sat May 18, 2019 1:11 pm by rjpjnk | ||
New member/ dyna filter caps | 2 | kb1_us | 710 | Sat May 18, 2019 11:38 am by kb1_us | ||
High frequency buzz in left channel ST-70 | 8 | Sfguitarworks | 808 | Thu May 16, 2019 1:32 pm by Peter W. | ||
Triode Boards | 2 | WPFW893FM | 1219 | Wed May 15, 2019 9:50 am by WPFW893FM | ||
Bias setting for MK III | 1 | MK134 | 696 | Tue May 14, 2019 2:48 pm by Peter W. | ||
Anybody need a ST-70/120 board cover? | 2 | slate1 | 903 | Tue May 14, 2019 1:05 pm by slate1 | ||
Octal Mk3 board pin 1 pin 6 V1 jumper | 1 | altecboy | 475 | Mon May 13, 2019 1:31 pm by altecboy | ||
New SP9 PH12 owner with ST-70 | 19 | Kray | 2218 | Sun May 12, 2019 11:03 pm by markeby | ||
Loud pop when turning off MK-III monoblocks? | 15 | ViperZ | 1271 | Sat May 11, 2019 3:52 pm by BryceJ | ||
ST-70 chassis to cage screw sizes? | 6 | Kray | 1408 | Thu May 09, 2019 6:08 pm by Dale Stevens | ||
Ear bud recommendation | 18 | wildiowa | 1448 | Thu May 09, 2019 1:26 pm by deepee99 | ||
Shielded cable for inputs? | 9 | ureche | 1122 | Sun May 05, 2019 3:55 pm by sKiZo | ||
VTA ST-70 rectifier issues - solved ! | 8 | Brap | 1414 | Wed May 01, 2019 5:38 pm by Pillo69 | ||
Auto-Bias board on Roy's website? 1, 2, ... , 5, 6 | 127 | mazeeff | 18649 | Tue Apr 30, 2019 6:26 pm by BryceJ | ||
Headphone Impedance Question | 6 | scrotuss | 654 | Tue Apr 30, 2019 5:07 pm by scrotuss | ||
Voltage reduction | 5 | 69Cutlass | 973 | Mon Apr 29, 2019 11:29 am by 69Cutlass | ||
B+ Too High? | 7 | drafalske | 1004 | Mon Apr 29, 2019 2:10 am by Tubes4ever | ||
ST-120 Issues - solved ! | 15 | thermionicvinyl | 1765 | Sun Apr 28, 2019 4:29 pm by Drummerboy2 | ||
SP 14 hum elimination | 2 | audiobill | 2461 | Fri Apr 26, 2019 5:24 pm by Roy Mottram | ||
Dynaco SCA35 | 17 | Peter W. | 2100 | Fri Apr 26, 2019 7:47 am by Peter W. | ||
PS Audio Directstream DAC | 19 | audiobill | 1373 | Thu Apr 25, 2019 5:55 am by audiobill | ||
PAS3 blend switch issue - no stereo on left channel | 5 | alyosha | 893 | Mon Apr 22, 2019 4:20 pm by Dale Stevens | ||
Got it today! | 2 | ImFritz | 787 | Fri Apr 19, 2019 8:30 pm by pedrocols | ||
Found on US Audio Mart VTA SP14 | 6 | ImFritz | 1364 | Fri Apr 19, 2019 2:24 pm by bluemeanies | ||
wtfplay for serious listening | 2 | buchela | 3289 | Mon Apr 15, 2019 2:49 am by buchela | ||
VTA SP9 Preamplifier | 0 | stewdan | 610 | Sun Apr 14, 2019 2:17 pm by stewdan | ||
To cool or not to cool? | 19 | Guest | 1010 | Sat Apr 13, 2019 4:58 pm by MrBlimp | ||
New to forum looking to rebuild Dynaco Mk 2s and a 3 1, 2, 3 | 68 | MrBlimp | 3739 | Fri Apr 12, 2019 5:15 pm by MrBlimp | ||
Dyna PAS control pot question | 3 | WLT | 621 | Fri Apr 12, 2019 2:36 pm by WLT | ||
12 Ohm Speakers through VTA ST-120 | 5 | bullmkt3 | 1033 | Wed Apr 10, 2019 8:49 am by bullmkt3 | ||
VTA ST-120 and new Magnepan 1.7i | 11 | ImFritz | 1775 | Tue Apr 09, 2019 10:45 am by Guest | ||
Auto bias and ST35? | 5 | corndog71 | 762 | Mon Apr 08, 2019 4:24 pm by Peter W. | ||
Cleaning vinyl records - video | 14 | Bob Latino | 1080 | Sat Apr 06, 2019 5:25 pm by ArlanB | ||
Tube Question | 2 | bluemeanies | 733 | Sat Apr 06, 2019 9:52 am by bluemeanies | ||
Listening Session | 20 | Brap | 1553 | Fri Apr 05, 2019 2:26 pm by bongoman | ||
Switch in B+ ST120 | 7 | ureche | 958 | Fri Apr 05, 2019 12:31 pm by ureche | ||
ST70 Possible power transformer issue - request for values - SOLVED | 0 | jrubin | 600 | Thu Apr 04, 2019 7:22 pm by jrubin | ||
Speaker Wire from Roy | 6 | Guest | 1290 | Tue Apr 02, 2019 10:46 am by 10-E-C | ||
I'm damaged goods. | 3 | bbqjoe | 731 | Sun Mar 31, 2019 3:01 pm by corndog71 | ||
VTA ST-120 with Maggie 1.7i | 15 | ImFritz | 1703 | Sat Mar 30, 2019 12:12 pm by deepee99 | ||
60 Hz Hum, and What it Feels Like | 3 | Peter W. | 601 | Fri Mar 29, 2019 3:34 pm by deepee99 | ||
Prefered rectifier tube for VTA ST-120 | 2 | ImFritz | 1560 | Fri Mar 29, 2019 2:09 pm by ImFritz | ||
SP14 tube layout. | 8 | FearOfMusic | 1950 | Wed Mar 27, 2019 12:28 am by Kentley | ||
ANK DAC 4.1 Build 1, 2, 3 | 62 | cci1492 | 5995 | Tue Mar 26, 2019 7:23 pm by audiobill | ||
Rules of thumb for testing tube amps | 2 | Midwestside | 909 | Mon Mar 25, 2019 7:13 pm by Midwestside |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 3 Guests
Registered Users: None
