Basket
Topics | Replies | Author | Views | Last Posts | ||
Announcement: dual rectifiers for ST120 & ST70 amps 1, 2 | 30 | Roy Mottram | 3894 | Sat Dec 02, 2023 6:27 pm by GAflubug | ||
Announcement: Tubes IN STOCK - Tung-Sol, Gold Lion, Electro-Harmonix, Svetlana, Sovtek, JJ | 2 | Dan W | 799 | Thu Sep 07, 2023 9:00 pm by Dan W | ||
Announcement: blown tubes | 0 | Roy Mottram | 1288 | Thu Jun 08, 2023 7:51 pm by Roy Mottram | ||
Blip Blip BLIP! | 14 | sKiZo | 1468 | Mon Dec 09, 2013 8:41 pm by pigface | ||
Joe Phelps and Dean Martin, a marriage made in Heaven. What are YOU drinking?? | 2 | Laminarman | 745 | Mon Dec 09, 2013 7:52 pm by Laminarman | ||
Check it out - new 5AR4s 1, 2 | 31 | Guest | 6740 | Mon Dec 09, 2013 5:07 pm by turbotoy | ||
SP 9 Chassis Layout | 3 | TN Allen | 1130 | Sun Dec 08, 2013 1:05 pm by peterh | ||
Rectifier tube? | 1 | Maintarget | 1224 | Sat Dec 07, 2013 5:47 pm by Bob Latino | ||
ST-35 power supply query | 1 | Guest | 871 | Sat Dec 07, 2013 3:13 pm by Roy Mottram | ||
Biasing issues 1, 2 | 30 | nerpissad | 3861 | Sat Dec 07, 2013 10:05 am by deepee99 | ||
Mark III with octal boards | 1 | Elrick | 1174 | Thu Dec 05, 2013 12:21 pm by pjp3 | ||
Pre amplifier | 11 | Laminarman | 2630 | Wed Dec 04, 2013 10:03 am by deepee99 | ||
SP14 tube roll - Capacitor upgrade saga | 8 | pigface | 3731 | Sun Dec 01, 2013 11:24 pm by pigface | ||
Add RCA Outputs To ST-70 | 0 | EddieGnz1 | 864 | Sun Dec 01, 2013 10:53 pm by EddieGnz1 | ||
Resetable hour meter | 4 | Maintarget | 1621 | Sun Dec 01, 2013 3:52 pm by sKiZo | ||
A-470 Output Transformer | 0 | Tarazed | 1892 | Sat Nov 30, 2013 5:20 pm by Tarazed | ||
Tube contact issues | 9 | Bob Latino | 1705 | Sat Nov 30, 2013 1:16 pm by sKiZo | ||
Add Standby to ST120? | 13 | sKiZo | 1504 | Sat Nov 30, 2013 12:29 am by sKiZo | ||
Can You Identify The Quadcaps On This PCB | 1 | EddieGnz1 | 1045 | Fri Nov 29, 2013 7:57 pm by Bob Latino | ||
Octal ST-70 driver and transformer | 2 | dougmon | 1689 | Fri Nov 29, 2013 1:36 pm by dougmon | ||
Mark II's....before I get too far | 0 | Backpacker85 | 816 | Mon Nov 25, 2013 1:41 pm by Backpacker85 | ||
VTA preamp questions | 11 | daveshel | 3954 | Mon Nov 25, 2013 1:29 am by sKiZo | ||
VTA SP Case Cover Necessary??? | 2 | guentherj2 | 1068 | Sat Nov 23, 2013 2:05 pm by Roy Mottram | ||
Dynavector 10x5 loading question | 4 | xlr8 | 3021 | Sat Nov 23, 2013 1:20 pm by xlr8 | ||
ST-70 Output Stage, Explained For Extreme Beginners | 14 | EddieGnz1 | 1702 | Sun Nov 17, 2013 3:56 pm by sailor | ||
Bozak CS-4005 speakers | 1 | wildiowa | 1301 | Sun Nov 17, 2013 2:17 pm by sKiZo | ||
Philips 5R4GYS Rectifier 1, 2 | 44 | sKiZo | 11207 | Sun Nov 17, 2013 12:27 am by skriefal | ||
6550s vs KT-88s plate dissipation | 3 | deepee99 | 1111 | Sat Nov 16, 2013 4:38 pm by skriefal | ||
12AX7 tubes comparison. | 1 | baddog1946 | 1391 | Sat Nov 16, 2013 3:53 pm by denny9167 | ||
Line level input voltage for Ultimate Pas Pre | 2 | Elrick | 1102 | Fri Nov 15, 2013 12:37 pm by GP49 | ||
Z565 output transformer question | 17 | Guest | 9879 | Thu Nov 14, 2013 3:06 pm by corndog71 | ||
Mark III w/ new octal board | 6 | Elrick | 1347 | Wed Nov 13, 2013 6:54 pm by Elrick | ||
Low filament voltage on st-70 | 15 | Serge_K | 1800 | Mon Nov 11, 2013 9:38 am by arledgsc | ||
latest SP14 preamp build | 2 | Roy Mottram | 2791 | Sun Nov 10, 2013 10:00 pm by Leigh W | ||
No variac... use a light bulb | 5 | j beede | 3729 | Sat Nov 09, 2013 1:34 pm by sKiZo | ||
Amp selection and what to expect with Paradigm Studio 100's | 11 | BigHead | 1531 | Sat Nov 09, 2013 11:03 am by arledgsc | ||
Dynakit PAS 2 Phono Stage? | 3 | tkemmett | 1367 | Fri Nov 08, 2013 12:47 pm by GP49 | ||
Mullard GZ34 | 13 | dougmon | 2106 | Thu Nov 07, 2013 1:44 pm by GP49 | ||
rare dynaco on the market | 10 | baddog1946 | 2082 | Thu Nov 07, 2013 1:39 pm by GP49 | ||
Struggling To Get Started in Tube Amps | 14 | EddieGnz1 | 2605 | Thu Nov 07, 2013 8:07 am by xlr8 | ||
SP-12 or SP-14 | 16 | Leigh W | 5341 | Wed Nov 06, 2013 7:55 pm by Tube Nube | ||
Which ST70 Kit To Buy | 7 | EddieGnz1 | 2040 | Tue Nov 05, 2013 7:17 pm by dmag | ||
SP 14 Question | 14 | WntrMute2 | 1988 | Sun Nov 03, 2013 7:38 pm by gener8r | ||
ST-120 Bias issue | 6 | sackchamp56 | 1448 | Sun Nov 03, 2013 7:24 pm by guentherj2 | ||
12at7 Breaking Bad | 4 | kaner | 1263 | Sun Nov 03, 2013 3:07 pm by Roy Mottram | ||
Need a little more low end in your system? Check out this woofer .. 1, 2 | 29 | Bob Latino | 5431 | Sun Nov 03, 2013 1:36 pm by sKiZo | ||
Point To Point, No Kit | 19 | EddieGnz1 | 2795 | Wed Oct 30, 2013 10:58 pm by corndog71 | ||
Size Really Matters !? | 3 | arledgsc | 1099 | Wed Oct 30, 2013 10:36 pm by sailor | ||
Marconi 12AU7 | 0 | sKiZo | 2601 | Mon Oct 28, 2013 6:21 pm by sKiZo | ||
VTA SP12 Popping Noise | 6 | guentherj2 | 1779 | Mon Oct 28, 2013 12:48 pm by Jim McShane | ||
PAS3 power supply | 7 | Roy Mottram | 3519 | Sun Oct 27, 2013 2:48 pm by Pillo69 | ||
12BH7 in VTA70 with stock power supply transformer questions | 12 | Mossback | 5335 | Sun Oct 27, 2013 12:34 am by sKiZo | ||
Tube store tube number | 13 | ValleySounds | 1873 | Sat Oct 26, 2013 11:25 am by ValleySounds |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 2 Guests
Registered Users: None
