    tube rectifier diode mod
    tube rectifier diode mod - Page 2 Empty Re: tube rectifier diode mod
    Post by arledgsc on Thu Aug 15, 2013 10:06 pm
    A bridge rectifier in a Dynaco amp or transformer center tapped secondary will perform identically as the two diode full wave rectifier with the following exceptions - bridge has two diodes on each leg in series (higher pk inverse voltage) and extra diode drop which is significant at low voltages.  So no real advantage in using bridge vs. full wave in a Dynaco design.  Bridge rectifiers are used in power supplies without a center tap secondary.  Full wave wouldn't work without the center tap connected to ground.  So which type to use depends on the power transformer secondary and the needed rectified voltage.
    And yes it is possible to use solid state diodes only.  But you have to be careful and make sure the B+ voltage doesn't creep up excessively and become a concern for the filter capacitor's working voltage margin.  Modern Dynaco type amps usually have a lot of extra capacitance so inrush current will be large and you may pop a fuse occasionally.  And a standby switch or a relay board is mandatory with solid state.  Weber makes a copper cap with diodes only (no series power resistor or thermistor) if you feel brave.  But though you will have a lower impedance power supply using diodes only.
    The Weber copper cap WZ68 is a good compromise between actual tube vs straight diode rectification.  The WZ68 mimics two GZ34s in parallel netting 1/2 the series resistance and double the current.  Works well in circuit meant for a vacuum tube rectifier.
    Post by corndog71 on Fri Aug 16, 2013 2:15 pm
    I wouldn't be using the typical can caps. My plan is to build a ST120 but using Clarity TC caps in the power supply. They're 700V rated and I would just put a 45uF cap at the start. I was planning to use the copper cap you mentioned but have been reading about Schottky diodes and thought those along with the delay circuit board might be a viable option.
    ricohman
    Post by ricohman on Sat Aug 17, 2013 12:10 am
    My ST-70 project came with this mod.
    I have been informed that was done to replace the tube. I will be removing these diodes and installing a tube. Then doing the diode mod as per the instructions here.
    tube rectifier diode mod - Page 2 DSC05517_zps6ca6aede
    Post by arledgsc on Sat Aug 17, 2013 10:02 am
    Yes, that is a full wave rectifier diode bypass mod with two diodes in series for probably higher peak inverse voltage.  How does it sound and what is the B+ voltage?   In a guitar amp I had to find the correct diodes to avoid diode switching hash noise.   The latest ultrafast recovery diodes meant for switching power supplies cause a lot of ringing when they turned off.  And you could hear it.   Finally found some old school Philips BYM26E diodes (fast soft recovery) and problem solved.   The diodes in the picture look similar to the Philips diodes used on my project.
    Post by corndog71 on Sun Aug 18, 2013 11:54 am
    So if i read this right I could just use the red wires with a pair of diodes similar to the ST35 and just not connect the pair of yellow wires that normally go to the rectifier socket. That's easy.
    guentherj2
    guentherj2
    Post by guentherj2 on Thu Sep 26, 2013 9:08 pm
    I found some rectifier diodes at The Shack that are 1000 PIV and 1.5A (Part Number 276-1114). I think the 1N4007s are 1A. Will these work for the rectifier diode mod on a ST120?
    More detailed specs of the RS diodes here:
    PIV: 1000V
    If: 1.5A
    Peak Surge Current (8.3ms): 50A
    Forward Voltage Drop: 1.1V
    Peak Reverse Leakage: 5uA
    Typical Total Capacitance: 20pF
    John
    Post by arledgsc on Fri Sep 27, 2013 12:40 pm
    "I found some rectifier diodes at The Shack that are 1000 PIV and 1.5A (Part Number 276-1114). "
    These are GP15M diodes with a slightly better current rating than a 1N4007.  Note though the size is about 1/3 larger than a 1N4007.  But should function OK in the circuit.
    guentherj2
    guentherj2
    Post by guentherj2 on Wed Oct 02, 2013 7:59 pm
    OK - I am working with the ST120 and I'd like to install the 1N4007 rectifier diode mod in hopes of prolonging the life of my rectifier tube.
    I have two red leads from the power transformer going to pins 4 and 6.
    Two white leads from the power transformer going to pins 8 and 2.
    Pin 8 is shared with a red lead coming from???
    I assume the two twisted pairs of wires, one red and one white, are from the power transformer. I've got the "yellow sheet" directions but those pin numbers don't match what I'm working with.
    Can someone please advise on where to put the two 1N4007 diodes?
    John
    Post by arledgsc on Wed Oct 02, 2013 8:10 pm
    Pin 8 shares double duty as one side of the filament heater (white) plus it is also the high voltage DC output that connects by a red wire to the quad capacitor can.  The reason for this is the rectifier cathode is directly heated.
    Instead of the two red AC wires connecting to the socket on pins 4 and 6 they are instead connected to pins 5 and 7.  The diodes connect between pins 4-5 and 6-7 to complete the circuit.   Be mindful to ensure the diodes are oriented with the cathode band on pins 4 and 6 repectively.
    The yellow sheet is clear on where to place the diodes but you are correct it does not illustrate the HV DC red wire on pin 8 that connects to the quad cap.
    guentherj2
    guentherj2
    Post by guentherj2 on Wed Oct 02, 2013 10:01 pm
    OK - I see I was looking at the completed mod, confused, and that the wires were as they are on my rectifier tube socket. Thanks for the clarification and roger that on the diode orientation.
    John
    scottlowe
    Post by scottlowe on Fri Apr 25, 2014 12:19 am
    should i do this to my vta st 120 ?
    guentherj2
    guentherj2
    Post by guentherj2 on Fri Apr 25, 2014 12:34 am
    I recommend you do it. It's easy and it may save you from having to replace your rectifier tube but I'm sure you could live without it.
    mantha3
    mantha3
    Post by mantha3 on Fri Apr 25, 2014 7:24 am
    I did this to my ST120 and I have a cheapo Sovtek GZ34 that is 9mo old. I listen loud fairly often too.
    I ended up going with a UF4007. the UF4007 is basically the same as a 1N4007 having 1A / 1,000 volt rating but a more modern Ultrafast recovery version diode. One post spoke of the UF4007 potentially limiting the possible “switching” you could hear. This “switching” got shot down by a few who talked about all the capacitance that would buffer this out. I also saw some conversations about the need to go with the full 1,000 volt and I read some detail about why the 1,000 volt diode is needed. I wish I could find it. I'm not as tec savy to have this in my head. I’d go safe and run the 1,000 volt and error on the side of over spec... So go UF4007 or 1N4007
    1N4007 is a $.09 each (http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/1N4007/?qs=sGAEpiMZZMuQUXCJI7Y4lvWy%252b1U8RtCq)
    UF4007 is $.49 each (http://search.digikey.com/us/en/products/UF4007/UF4007CT-ND/965732)
    Post by arledgsc on Sat May 24, 2014 10:47 am
    The fast recovery diodes in a guitar amp I built caused hash noise.   The fast switching induced ringing in the rectified voltage.  Found some "fast soft recovery" diodes that cured the problem.  The amp was straight solid state rectified and no tube involved.  Fast recovery diodes are an overkill for slow commutation 50/60 Hz AC rectification.  But if you hear no noise then no problem with either diode.
    The 4007 peak inverse voltage of 1kV rating may not be quite enough in an ST-120.  If the tube rectifier blows (shorts) you can have +500V dc on the output and on the input side of the protection diodes over -500V peaks as the AC swings negative.  If I were purchasing diodes for the ST-120 I would consider the higher rated 4008s at 1.2kV peak inverse voltage.  In normal operation the 4007s are fine with effectively two diodes in series.   Just the spec could be exceeded on specific tube failures.
    Post by tubes4hifi on Sat May 24, 2014 2:20 pm
    don't forget you can always put diodes in series to double their effective voltage rating
    telefunking
    Post by telefunking on Tue Jun 10, 2014 7:46 am
    good morning fellas i have a question,im looking at a st70 its out of state so i cant test it .the seller said he hooked it up.the voulume on one channel was real low.the other channel was fine..as i stated i cant put my hands on it to trace the problem...worst case output transformer? resistor ? and or recterfier tube? output tube? any ideas of what i might have to fork out to fix..
    Post by tubes4hifi on Tue Jun 10, 2014 10:42 am
    it probably is all original and has a weak tube or worn out components on the driver board.
    Replace with our VTA70 driver board and new tubes (and most likely a new quad cap) and most likely you'll be all set!
    Post by GP49 on Tue Jun 10, 2014 11:05 am
    telefunking wrote:good morning fellas i have a question,im looking at a st70 its out of state so i cant test it .the seller said he hooked it up.the voulume on one channel was real low.the other channel was fine..as i stated i cant put my hands on it to trace the problem...worst case output transformer? resistor ? and or recterfier tube? output tube?
    Yes.  Any of the above.  A Stereo 70 can be anything up to 56 years old.  It could have been pampered through its lifetime, or played hard and put away wet.  There is no way anyone on this board can diagnose that amplifier with the information provided, especially since the information is secondhand from someone who wants to sell it.
    Best assume that he wants to get rid of some problems he's got with it.
    No.
    When buying a used amplifier like this, it is best to assume that you will have to put something into it.  Even if the amplifier's circuitry has not developed any problems, tubes have a finite life and you'd best count on replacing the output tubes (the 7199 driver tubes last much longer...but getting good replacements can be more difficult).  Since the amplifier does turn on and produce some sound ("fine" to some may mean "rife with distortion" to someone else), at least you know the power transformer and rectifier tube are good.
    I know this isn't the slam-dunk, "This is what your problem is and it will cost $2.98 to fix it" you wanted, but it's the reality of buying an old, used tube amplifier.  The purchase of a vintage Stereo 70 is not a "turnkey" deal, like going to the store and buying new equipment.  You will have to put a little of yourself into it, along with a little (or a lot) of your money.
    Ed Rosenberger
    Post by Ed Rosenberger on Tue Nov 04, 2014 6:52 pm
    The very first post (by Roy) in this 2011 sticky thread showed a diode modification sketch to extend the life of the rectifier tube (I tried to copy it here but totally failed).
    My question is.....is this still a valid mod? The newest VTA ST70 kit drawings do not show these two diodes being used on the rectifier tube socket.
    The diodes are an extension of the two red power transformer wires, so I doubt these diodes would have ended up anywhere else.
    Thank you,
    Ed
    Post by stewdan on Tue Nov 04, 2014 8:10 pm
    Hi Ed -- Yes, the Diode Mod is still valid!! It is valid for the original ST-70 and the VTA70. It can safely be stated to be valid for all amplifier units that use the GZ34/5AR4 Rectifier Tube.
    There was also some discussion on the board of using the Diode Mod with the Weber Copper Top Rectifier WZ68 which replaces the GZ34.  Some have mentioned using the Mod with GZ37 or GZ33 Rectifier Tubes.
    Hope that answers your question,
    Stewart
    Ed Rosenberger
    Post by Ed Rosenberger on Tue Nov 04, 2014 11:04 pm
    Thank you for your reply Stewart!
    A lack of those installed diodes may be why I've read of people advising others to have some spare 5AR4 tubes. Guess I'd better round up a couple IN4007 diodes.
    Double checked the sent kit parts and no diodes or notes were added. Wonder why not.....they're cheaper than buying those tubes Wink.
    Thanks again Stewart.....
    Ed
    Ed Rosenberger
    Post by Ed Rosenberger on Wed Nov 05, 2014 5:06 pm
    For those who may be searching for 1N4007 (1000V/1amp) rectifier diodes, I found them here:
    http://www.ebay.com/itm/161175215237
    Ten of them with free shipping for $1.79.....don't see how they can do it and make money. That is much less expensive than Radio Shack and the diodes are only available in a 25 piece assortment.....may only get one 1N4007 according to some reviews.
    MexicoMike
    Post by MexicoMike on Sat Nov 29, 2014 10:01 am
    I'm not understanding how those diodes can aid tube life.  Aren't they just passing current to the tube that would be there anyway?  I can't see how a diode actually does ANYTHING in that application but I readily admit I am not a circuit designer.  I am NOT disagreeing; I just don't understand what, exactly happens where the diodes are useful.  Feel free to send me to some existing explanation rather than posting something that is already clearly explained elsewhere.
    Post by arledgsc on Sat Nov 29, 2014 12:20 pm
    Addition of the diodes prevents current flowing in the reverse direction.  How can this ever be? In the event of a power failure the power supply caps are fully charged.  The rectifier tube is now reversed biased with a cooling cathode and potential for an arcing is highest which usually destroys the rectifier.
    dmtparker
    dmtparker
    Post by dmtparker on Sun Dec 07, 2014 3:49 pm
    When using 2 diodes in series like this (referring to post 15), it is best to use resistors (something like 330k) across each one to be sure they "share the load" equally. That begins to be a challenge fitting it into the space available, I admit.
    Another alternative is to just replace the Tube rectifier with a ss full wave bridge (I used a total of 4 iN4007's and 4 330k R) PLUS something like 50 ohm 10 W R between the output of the bridge and the first cap (This mimics the resistance of the tube rectifier and prevents voltage from going WAY high).
    Last edited by dmtparker on Sun Dec 07, 2014 4:03 pm; edited 1 time in total (Reason for editing : Did not reference original post first time)
      Current date/time is Thu Feb 27, 2020 10:25 pm
