    Size of the SCA35 and ST35 boards
    sailor
    Size of the SCA35 and ST35 boards Empty Size of the SCA35 and ST35 boards
    Post by sailor on Wed Nov 16, 2011 4:28 pm
    I know that the boards for the sca and the st are different. My only question is are they the same size? I have an sca and would like to bypass the controls and go right to the amp and possibly replace the boards with st boards if they will fit.
    Size of the SCA35 and ST35 boards Empty Re: Size of the SCA35 and ST35 boards
    Post by Bob Latino on Thu Nov 17, 2011 12:05 pm
    ST-35 boards are 2 inches wide by 5 1/8 inches long
    sailor
    Post by sailor on Thu Nov 17, 2011 1:04 pm
    `Thanks Bob, very close, if not the same, I measured it 2" by 5 and 3/16". I guess the next question is the screw hole distance. On the SCA they are 4.80" X and slightly more than 1.5"
    Post by tubes4hifi on Thu Nov 17, 2011 8:10 pm
    ST35 PCBs are 2.0" x 5-1/8" and hole spacing is 1-5/16" x 4-7/8"
    sailor
    Post by sailor on Fri Nov 18, 2011 4:55 pm
    It seems that the 2 boards are almost If not exactly the same size. Without removing the screws I came up with 4 and 7/8 by 1 and5/16 also for the SCA board. If this is the case, it opens up the door for a lot of modifications to the SCA.
    DynakitParts
    DynakitParts
    Post by DynakitParts on Sat Nov 19, 2011 7:35 am
    Sailor,
    Both boards are identical in size and hole mounting.
    Kevin @ Dynakit
      Current date/time is Thu May 23, 2019 7:59 am
