    4 x KT88 Guitar Amp using M-125 Iron Set, now with pic of driver circuit
    Tom
    Re: 4 x KT88 Guitar Amp using M-125 Iron Set, now with pic of driver circuit
    Post by Tom on Thu Dec 15, 2011 6:43 am
    Thanks, I've heard the "too complicated" comment before.
    I built the SP-8 preamp with phono and line stages on the same board,
    and it burns me that the phono tubes are burning
    while I'm listening to the line stage.
    Haha!
    Smile
    Luddite
    Post by Luddite on Thu Dec 15, 2011 9:31 am
    Tom wrote:Thanks, I've heard the "too complicated" comment before.
    Haha!
    Smile
    As far as I know, no commercially produced (single chassis) tube preamplifiers have ever offered a provision for separately powering up the line and phono stages. Yes, it increases the complexity which also increases the cost. The difference probably being enough to purchase a spare set (or two) of replacement tubes.
    Best Regards,
    Charlie
    Tom
    Post by Tom on Thu Dec 15, 2011 2:29 pm
    Ah! That rings of challenge.
    If cost, complexity or even rationality
    had anything to do with,
    we'd still be listing to our first Close-n-Play.
    (albeit with a cartridge upgrade)
    Wink
    dunwichamps
    Post by dunwichamps on Thu Dec 15, 2011 2:31 pm
    It could be done but requires some thought, You could have a 3PDT switch which 2P switch the signals while a 3P actuates a bunch of relays which remove the cathode grounds on the phono pre stages. that would be costly in terms of space and complexity but doable if you really wanted it
    Post by GP49 on Thu Dec 15, 2011 5:16 pm
    dunwichamps wrote:It could be done but requires some thought, You could have a 3PDT switch which 2P switch the signals while a 3P actuates a bunch of relays which remove the cathode grounds on the phono pre stages. that would be costly in terms of space and complexity but doable if you really wanted it
    And do you really WANT relay or switch contacts on the cathode grounds? Everything that flows in the plate circuit...and that is
    what constitutes the sound that the tube stage "makes"...flows through the cathode, too. Whatever you do at the cathode, affects the sound.
    Last time I looked, a straight soldered connection is still better than the BEST contact.
    I say, "not worth the effort."
    dunwichamps
    Post by dunwichamps on Thu Dec 15, 2011 5:19 pm
    well i merely suggested how it could be done not that I would do it. I dont see much harm just letting the tubes idle all day which is why I just had switched inputs.
    Post by GP49 on Thu Dec 15, 2011 10:55 pm
    dunwichamps wrote:
    well i merely suggested how it could be done not that I would do it. I don't see much harm just letting the tubes idle all day which is why I just had switched inputs.
    Agree with you, there! Typically tubes in low level stages have a very long life anyway, so the gain isn't worth the effort.
    dunwichamps
    Post by dunwichamps on Thu Dec 15, 2011 11:01 pm
    i dont do much hifi stuff so I am typically ignoring hifi concerns in the design, that headphone amp was a special gift for my grandfather's 50 wedding anniversary and my 1st foray into building a stereo amp. Most of the time I am thinking about how I can absolutely make people deaf with huge guitar rigs.
    dunwichamps
    Post by dunwichamps on Tue Apr 10, 2012 2:12 pm
    build is just about to get rolling
    here are the turret boards I fabricated for the build
    the choke, power cord, and that small enclosure is for a footswitch
    some other random items, tubes, a small hammond PT for the bias supply
    dunwichamps
    Post by dunwichamps on Tue May 01, 2012 10:01 pm
    main circuit board and main power board are coming along
    dunwichamps
    Post by dunwichamps on Mon May 07, 2012 12:20 am
    chassis is in, dry fitting stuff to it
    dunwichamps
    Post by dunwichamps on Thu May 10, 2012 11:30 pm
    davidness
    Post by davidness on Fri May 11, 2012 9:20 am
    You would be good at Tron. Very Happy
    dunwichamps
    Post by dunwichamps on Fri May 11, 2012 9:30 am
    davidness wrote:You would be good at Tron. Very Happy
    ive never played it but possibly if my wiring style translates well.
    dunwichamps
    Post by dunwichamps on Fri May 18, 2012 2:04 pm
      Current date/time is Sat May 25, 2013 4:59 pm
