    Reducing st35 output.
    dmag
    dmag
    Reducing st35 output. Empty Reducing st35 output.
    Post by dmag Fri Jul 13, 2012 7:05 am
    Lately Ive come to really enjoy EL84 tube amps One is my st35.I'm beginning a rebuild of two amps.I would like to use Genelex Gold Lions for the output tubes.
    I have been advised that this amp overdrives them and they would last a very short time.
    Any suggestions how to reduce the total power tube dissipation to 11 watts?
    Idle current reduction?
    Also how would this relate to a sca35,
    as that will be a project once I get my hands on a project quality donor.
    Thanks in advance.
    Sal
    Sal
    Reducing st35 output. Empty Re: Reducing st35 output.
    Post by Sal Fri Jul 13, 2012 9:19 am
    I would highly recommend Dynakitparts.com ST-35 BCU bias control upgrade kit as you can individually set the bias of each EL84 tube. You can then set the bias to your desired level to increase tube life. Go to http://dynakitparts.com/store/product.aspx?id=293 for more information.
    You can also install this upgrade in a SCA-35.
    Regards,
    Sal
    Post by Guest Fri Jul 13, 2012 9:22 am
    Or, you could implement D. Gillespie's Enhanced Fixed Bias which knocks down quiescent current to 27mA from 35mA in the output tubes.
    Post by Bob Latino Fri Jul 13, 2012 10:56 am
    Both Sal and Captain Coconut have given good advice. A quick and inexpensive thing you could also do is to replace the 95 ohm common cathode resistor found on the quad cap with about a 120 ohm 5 watt resistor. This would (depending on your line voltage) also bring the idle current from 35 mA per output tube to about 27 to 28 mA per output tube.
    Jim McShane
    Post by Jim McShane Fri Jul 13, 2012 8:23 pm
    Bob Latino wrote:Both Sal and Captain Coconut have given good advice. A quick and inexpensive thing you could also do is to replace the 95 ohm common cathode resistor found on the quad cap with about a 120 ohm 5 watt resistor. This would (depending on your line voltage) also bring the idle current from 35 mA per output tube to about 27 to 28 mA per output tube.
    Bob, that's true - but the lower current reduces the load on the power supply and the voltage increases. So you have a bit of a balancing act to do.
    I agree, the two prior posters gave very good advice. The Genalex will not take more than 12 watts dissipation but I recommend a max of 11 in case of a high AC line or similar that increases the dissipation.
      Current date/time is Fri Mar 29, 2024 4:47 am
