    PAS 3 Question
    cartek
    PAS 3 Question
    Post by cartek on Fri Dec 23, 2011 11:35 am
    Hi. New here, but have had Dynaco stuff for about 10 years now. (PAS 3, FM 3, and used to have an ST 70). Very interesting reading so far. I have an issue with my volume control on the PAS. Would like to change it out for an Alps control. The Alps has no tap for the loudness feature. Will I lose all tone control if this is not connected?
    Merry Christmas, Dan
    Sal
    Re: PAS 3 Question
    Post by Sal on Fri Dec 23, 2011 11:50 am
    No, you do not lose your tone controls. Your loudness switch will not function with the Alps potentiometer.
    Merry Christmas,
    Sal
    Re: PAS 3 Question
    Post by tubes4hifi on Fri Dec 23, 2011 2:56 pm
    loudness function is something that gives an automatic variable bass boost depending on volume setting,
    usually only on the first 1/3 rotation of the volume control, but it is separate and not dependent on the tone controls
    cartek
    Re: PAS 3 Question
    Post by cartek on Fri Dec 23, 2011 3:19 pm
    Thanks for the quick replies! This is good news about the tone controls. I do not use loudness anyway. I do however, play some recordings that need a little tweakng.
    Dan
    cartek
    Re: PAS 3 Question
    Post by cartek on Sun Jan 29, 2012 11:20 pm
    Update: New volume control is installed. I don't know how it works yet because I decided to do a couple of other mods as well. I built up a new RCA connector strip, then found a nice selector switch in my stash of parts, it is a ceramic type, now I have to do the phono board mods... Thats what I'm into now, need to order the appropriate caps. I know the filament supply is a weak link, but, it tested out fine electrically, including the filters. These caps have held their value, and ESR is also very good I may leave this for another time. I am, however going to install a fuse in the primary line circuit, just in case. It's a tough one, the line between "git 'er done" and do all the stuff at once, 'cause I just wanna hear some tunes! Using a Heathkit AA-32 integrated in the meantime. (It needed a bit of tlc, but at least I got something in the interim)!
    Dan
    Westy56
    Re: PAS 3 Question
    Post by Westy56 on Mon Jan 30, 2012 10:40 am
    cartek wrote:Update: New volume control is installed. I don't know how it works yet because I decided to do a couple of other mods as well. I built up a new RCA connector strip, then found a nice selector switch in my stash of parts, it is a ceramic type, now I have to do the phono board mods... Thats what I'm into now, need to order the appropriate caps. I know the filament supply is a weak link, but, it tested out fine electrically, including the filters. These caps have held their value, and ESR is also very good I may leave this for another time. I am, however going to install a fuse in the primary line circuit, just in case. It's a tough one, the line between "git 'er done" and do all the stuff at once, 'cause I just wanna hear some tunes! Using a Heathkit AA-32 integrated in the meantime. (It needed a bit of tlc, but at least I got something in the interim)!
    Dan
    Lucky you, the Heathkit is a very fine sounding unit.
    Steve
    Re: PAS 3 Question
      Current date/time is Fri Apr 20, 2018 1:08 am
