    St-70 upgrades
    Re: St-70 upgrades
    Post by GP49 on Thu Jan 19, 2012 11:37 am
    burnedfingers wrote:bktheking
    It is common practice to use the correct connector for the application...I would not dream of using an XLR connector for anything other than a mic or line connector just to make sure that something doesn't get plugged in where it shouldn't.
    The best example of why NOT to use incorrect connectors: people who used to use regular household plugs/jacks on their SPEAKER WIRES for easy connect/disconnect.
    Sooner or later the speaker got plugged into a wall outlet, and POOF!
    burnedfingers
    Re: St-70 upgrades
    Post by burnedfingers on Thu Jan 19, 2012 8:06 pm
    http://www.abbatron.com/index.php?cPath=29_78_47
    This should get you some jacks to look at. They will be close to what I pictured. It appears that I purchased some left over stock from a local electronics shop that they discounted. The number I have on my box is 256 103 Jack and it doesn't seem to play.
    Side note here* I used insulated washers on both sides of the chassis. If you laid out your hole centers at .750 then a common banana jack can be inserted into both the neg and positive jacks at the same time. One step further would be to make up a harness that plugs into your meter.
    Luddite
    Re: St-70 upgrades
    Post by Luddite on Thu Jan 19, 2012 11:37 pm
    burnedfingers wrote:http://www.abbatron.com/index.php?cPath=29_78_47
    BTW, the referenced page link is for "tip" jacks (very similar to what I suggested previously). Those will fit standard test probes. If you prefer to use "banana" jacks go to this page link:
    http://www.abbatron.com/index.php?cPath=29_78_44
    Best Regards,
    Charlie
    burnedfingers
    Re: St-70 upgrades
    Post by burnedfingers on Fri Jan 20, 2012 7:47 am
    To each his own but this is my setup on one of my amps. A cheap $2 meter that is accurated and banana jacks set on a .750 c-to-c and a standard banana jack with meter leads will slide right in. The advantage to this setup is the meter probe tips will not accidentally come out. Just my .02
    quad
    Re: St-70 upgrades
    Post by quad on Sun Jan 22, 2012 7:18 am
    Explain?
    What they said...those meter type jacks are what I suggested to you to over on AK...
    http://audiokarma.org/forums/showpost.php?p=5312290&postcount=18
    Re: St-70 upgrades
      Current date/time is Wed Jan 17, 2018 4:54 am
