    Operating voltage for output section of ST-70
    SuperB
    Post by SuperB on Mon Jan 02, 2012 2:25 pm
    Hey!
    Since I want to separate the power supply for driver and output section on the ST-70. And I want to run 440V on the output tubes (EL34), what is the operating current should I settle for 440V.
    Also, I want to put a OPT with 5K primary to replace the A470. What is circuit change require?
    Thanks!
    Re: Operating voltage for output section of ST-70
    Post by tubes4hifi on Mon Jan 02, 2012 3:23 pm
    if you allow 50ma of current for each EL34 output tube, then you'll need a total current of 200ma.
    you shouldn't need any changes for the output transformers, other than possibly fine-tuning the negative feedback capacitor value.
      Current date/time is Mon Apr 23, 2018 1:33 am
