    FM-3 Transformer Specs
    denny9167
    denny9167
    FM-3 Transformer Specs Empty FM-3 Transformer Specs
    Post by denny9167 on Thu Mar 01, 2012 7:35 am
    Does anyone have specs for the PT used in the FM-3? I have a bad transformer,and need a replacement. Edcor has a transformer that is really close in specs,The only spec I'm really needing is the current output for the HV tap. I'm also considering a custom design by Edcor,and I'm hoping it's close to a design they have on file,to waive the setup fee. Thanks
    DynakitParts
    DynakitParts
    FM-3 Transformer Specs Empty Re: FM-3 Transformer Specs
    Post by DynakitParts on Thu Mar 01, 2012 11:52 pm
    Hi Denny,
    Not sure of the specs on this...but check out Ebay Item # 220966885324
    Kevin
    denny9167
    denny9167
    Post by denny9167 on Fri Mar 02, 2012 10:31 pm
    DynakitParts wrote:
    Hi Denny,
    Kevin
    Thanks,I decided to bid on it!!!
    P.S. The Edcor transformer has specs rated at 350mA at 500VCT,and 6.3V at 7A which should be plenty for the number of tubes. It is slightly larger than the Stock Dynaco,but shouldn't be to much trouble.
      Current date/time is Sun Aug 18, 2019 3:53 am
