by Rec Wed Feb 16, 2022 10:15 am
Yea with 8 tubes it is almost impossible to keep a matched quad and a fat wallet. One will invariably blow first and need to be replaced, for whatever reason. Honestly, if you pull tubes to work on the amp or whatever reason, things can get mixed up!
Im with rebellovw here, although I dont mix tube vendors and a "try" to get close with the replacement. Just re bias. Never an issue.
The unit ships with a schematic, after a quick look, Im guessing it's more than just adding 2 pots per side. I'd guess that for the M125 this would add more than just two bias pots, and more opportunity to be concerned about "mismatch" (eg probably a 1/2 12AU7/coupling cap per tube). All this happens on the driver board. The 120 has individual tube bias. *Maybe* you can just use a 120 driver board with a few resistor tweaks to hit M125 B+ voltages and run the input stage in parallel?
I wouldn't overthink it. Just watch your bias every. As I type I am enjoying my (biased) M125 and I have no clue as to whether any tube matches.
Juice is not worth the squeeze in my opinion, and would likely introduce complexity in the preamp stage that could negatively affect the sound.
