    KT-66 question
    cc43fan
    cc43fan
    KT-66 question  Empty KT-66 question
    Post by cc43fan on Sun Apr 01, 2012 10:46 am
    I've completed my ST-70 restore, and the amp has about 20 hours on it using EL-34's. It's been rock solid, no hum, buzzing, and bias has stayed spot on. Last night I put KT-66's in the amp, and as soon as it warmed up, the KT-66's flashed bright light at or near the getter and a crackle sound came from the right channel. I instantly shut it down. I put the EL-34's back in and all was fine. I'm using the SDS power supply and VTA driver board. I have a 12AU7 in the center position and 12BH7's on the outside. The KT-66's I purchased are used, and I assumed were good.
    I shut it down as soon as I saw the flash and heard the crackle, but I have no experence with this tube so I don't know if that's "normal", but I'm guessing it's not.
    Can anyone shed some light on what I experenced, any thoughts on what is wrong (if anything), and possible solutions?
    Chuck
    KT-66 question  Empty Re: KT-66 question
    Post by Tube Nube on Sun Apr 01, 2012 11:05 am
    All of them flashed? Are they Mullards?
    cc43fan
    cc43fan
    Post by cc43fan on Sun Apr 01, 2012 11:14 am
    Tube Nube wrote:All of them flashed? Are they Mullards?
    Only the right channel flashed. I turned it off quickly so I think I didn't give the left channel to flash (or I didn't see it). The tubes are valve art.
    Post by Tube Nube on Sun Apr 01, 2012 6:13 pm
    Darn. I thought if they were Mullards, then you'd have your explanation. They flash brighter when they first come on, then settle down.
    cc43fan
    cc43fan
    Post by cc43fan on Wed Apr 04, 2012 10:26 am
    I solved it. Thanks to those who offered help.
    Alan-14
    Alan-14
    Post by Alan-14 on Thu Apr 05, 2012 5:35 pm
    What was the problem?
    cc43fan
    cc43fan
    Post by cc43fan on Thu Apr 05, 2012 7:30 pm
    Alan-14 wrote:What was the problem?
    Tube was bad.
      Current date/time is Mon Aug 26, 2019 6:27 am
