    ST 70 Mono-Stereo switch on the front of my amp.....Question???
    vincentdsnt
    ST 70  Mono-Stereo switch on the front of my  amp.....Question??? Empty ST 70 Mono-Stereo switch on the front of my amp.....Question???
    Post by vincentdsnt Thu Apr 12, 2012 9:54 pm
    This is my question........Is the Mono-Stereo switch on the ST70 used if you want to run two amps in mono (as in mono block), i.e. 60 watt amp per channel or is it to select between mono and stereo format?? Thank You for your help.
    ST 70  Mono-Stereo switch on the front of my  amp.....Question??? Empty Re: ST 70 Mono-Stereo switch on the front of my amp.....Question???
    Post by GP49 Fri Apr 13, 2012 12:16 am
    It parallels the two channels into one, sending one channel's input to both amplifier channels as a monoblock amplifier; the outputs of the two amplifier channels are connected together to drive a single channel's loudspeaker. However, as has been discussed here before, this mode of operation is useless for high quality sound. In normal stereo operation, negative feedback signals are intended to correct nonlinearities IN EACH CHANNEL INDIVIDUALLY; when the two channels are paralleled, the feedback signals get combined, too; thus they do not perform this same correction, causing distortion to rise sharply. It does not even double the power, as claimed.
    vincentdsnt
    Post by vincentdsnt Fri Apr 13, 2012 5:25 am
    GP49, Thank You.........for some reason I thought an ST could be used as a mono block amp, but then I am new to the ways of stereo amp knowledge.
      Current date/time is Fri Mar 29, 2024 1:48 am
