by 1973shovel on Mon Apr 23, 2012 6:22 pm
Bob Latino wrote:Sometimes even a couple of volt rise on your AC line voltage can cause noticeably higher AC voltages on the power transformer. As a result all your AC and DC voltages on the amp will be higher. Higher than normal line voltages will also shorten tube life especially the rectifier tube. If your amp is going through a few rectifier tubes each year, you should check your line voltage. If your line voltage is more than 121 volts, I would run your amp off a variac set at 118 volts. The amp will sound the same with no noticeable loss of power and your tube life will increase.
This is why I like using a CL-90 inrush current limiter, yes, even when using a 5AR4. I have a CL-90 mounted in an external outlet box, which I plug my various Dynaco amps into, then the outlet box plugs into the wall. As an example, I just checked my wall voltage at 122.6 VAC. I plugged my VTA ST-70 (with a 5AR4 rectifier) into the external CL-90 equipped outlet box and turned it on. The voltage feeding the ST-70 measured 119.7 VAC after the two minute ramp-up time.
The added benefit, in addition to the AC voltage drop, is that the switch, power transformer and 5AR4 are given a ramp up rather than being hit with full voltage and current. Some claim this will increase their longevity. A Variac is a better solution, but they cost several hundred dollars new. A CL-90 is $2.25 at Dynakit parts!
Note: I put the CL-90 into an external box because I only had one on hand, and with the external box I could use it with a few different Dynaco amps I own. For practical purposes, installing a CL-90 inside the amp is the way to go. One word of caution: Allow them some ventilation. They
DO get hot!
