On the PC-3, what location numbers go to the left and right front bias socket pin? Is it location 3 and 18 on PC-3 to pin 5 of the sockets?
Bob Latino wrote:Yes - In regards to a STOCK Dynaco driver board > On the left channel pin 5 on the front socket goes to eyelet #3 on the driver board. On the right channel pin #5 on the front socket goes to eyelet #18.
Bob Latino wrote:Correct - Those connections to pin 5 on the front tube sockets are not needed.
If you have ANY ST-70 IMHO > You should just use a GZ34 tube rectifier. The Weber WZ34 and WZ68 solid state rectifiers do have a short built in time delay of 3 to 5 seconds. Over the past few years, I have found that this short delay on the Weber rectifiers is enough to delay the application of high voltage until the filaments come on.
jgsulliv wrote:I'm a newbie to this forum and to tube audio in general. I've replaced caps in a magnavox 9304-20 and recently bought an ST 70 and PAS 3 with the intent to do the same.
Well, one thing leads to another and I now have new VTA board with PIO caps, new quad cap, RCA inputs, new Triode PA 60S and Triode SS chassis.
The reason I chose the Triode chassis is that it eliminates the superfluous power take off sockets (PTO) for a "cleaner" look (to my eye, anyway).
So, here's my question. How do I handle the bias test points? In the VTA instructions, bias left and right go to PTO pins 4 (back tube) and 8 (front tube).
There are only two holes for bias test points in the Triode chassis. Do I need to drill two more holes for bias test points for the back tubes ? Can I ignore (eliminate) all other wiring to the PTO javascript:emoticonp('')
Thanks for any light you can shed here.
Jim
