    multiple preamp outputs
    rockinrob86
    multiple preamp outputs Empty multiple preamp outputs
    Post by rockinrob86 Thu May 24, 2012 10:56 am
    I built an SP8
    In some of the pictures, I see multiple outputs. There are resistors connecting the hot contacts on the RCAs
    What values are these resistors, and why are they there?
    I am assuming they prevent some type of loss that would occur from just wiring the outputs in parallel, correct?
    multiple preamp outputs Empty Re: multiple preamp outputs
    Post by Roy Mottram Fri May 25, 2012 10:45 am
    I usually use 1K resistors, the value isn't critical, it just provides a little bit of isolation between the two outputs,
    and isn't absolutely necessary.
    plexus
    plexus
    Post by plexus Fri May 25, 2012 12:41 pm
    and more parts in the signal chain. Sad
      Current date/time is Thu Mar 28, 2024 6:02 pm
