As I stated in my one and only other post, my next project was to build an integrated stereo amplifier with phono stage included. I have modeled the project, snapshots shown below, aquired all hardware, except toroids, and have started machining the chassis. I won't spend much time describing the chassis build since it may be too far off base from the intended purpose of this forum. Questions (read as requests for advice) as well as more details to follow.
Goals: Less than 65 lbs., less than 19 inches wide. So far, have met the two physical goals. (See, not 4 feet wide, Roy!)
Regards,
Ken
View from the bottom without bottom panel in place.
Top view with only the KT-88s and rectifier tubes modeled. 19 tubes total.
Regards,
Ken
