    Russian Tung Sol 6L6g = 6L6gc ? for old dynaco ouput tubes
    lilwing
    Russian Tung Sol 6L6g = 6L6gc ? for old dynaco ouput tubes Empty Russian Tung Sol 6L6g = 6L6gc ? for old dynaco ouput tubes
    Post by lilwing Wed Jul 25, 2012 10:15 pm
    My old ST70 is healthy and running fine with EL34s.
    I'm not a tech.
    I'd like to put this new reissue quad of 6l6g's in place of the EL34's.
    I've heard these work great and I just like the way they look.
    I guess I'll need to re-bias the amp. I've never done anything like that. I always have my tech do stuff like this.
    I called my tech and for the first time he told me he didn't know anything about that.
    So is this something I can do with out wiring mods and just a cheap multimeter or shall I keep looking for a better tech?
    I live in the Portland OR area.
    I'd welcome any help. Especially pictures or a coloring book or something.
    Russian Tung Sol 6L6g = 6L6gc ? for old dynaco ouput tubes Empty Re: Russian Tung Sol 6L6g = 6L6gc ? for old dynaco ouput tubes
    Post by Bob Latino Thu Jul 26, 2012 6:35 am
    You can use 6L6's in any ST-70. If you have an original ST-70, you can bias the 6L6's the same as an EL34.
    The general recomendation from Roy and myself is that biasing these amps at Dynaco's recommendation of "1.56 VDC" per each channel is probably a little high with the tubes made today. Dynaco got away with it years ago because they shipped the ST-70 amps with Mullard EL34's. The Mullard EL34's were some of the finest sounding, most durable EL34 tubes ever made. They would take the high bias point (about 50 milliamps per each output tube) in stride. The general recomendation now is to bias these original boarded ST-70's at about 1.25 VDC per channel which gives about 40 milliamps bias current per each output tube. Your tubes will last longer and the amp will sound the same. I still have one totally original ST-70 here. I have biased this amp at 1.56 VDC and at 1.25 VDC. I cannot tell the difference in the sound of this amp.
    Biasing an original ST-70 is not difficult to do. Connect the speakers and turn the amp ON and wait a couple of minutes for the amp to warm up. Make sure that the amp is at idle. (no music being played) Set your multimeter to the 0 to 2 volt DC scale. Place the RED probe in the front hole of the left front tube socket that says "BIASET 1.56V" and the BLACK probe any where on the chassis. Adjust the left bias pot so that the meter reads 1.25 VDC. Now do the same the same on the right channel. If you go back to the left channel the bias that you set at 1.25 VDC will now probably be a little low. Go back and forth between the two channels until both channels read 1.25 VDC. What you have done is made an "initial" bias setting. Over the next half hour as the tubes warm up the bias will creep up slightly and the 1.25 VDC that you set initially may now be 1.37 VDC or something like that. After a half hour when the amp is fully warmed up READJUST the bias to 1.25 VDC on both channels.
    lilwing
    Post by lilwing Thu Jul 26, 2012 11:56 am
    Bob, I could not have asked for a more succinct answer to my question.
    Sounds wonderful. Thanks!
    Russian Tung Sol 6L6g = 6L6gc ? for old dynaco ouput tubes 2012-07-26074954
      Current date/time is Fri Apr 19, 2024 9:49 am
