    Guitar Amp Built out of M-125 Iron Set
    dunwichamps
    Post by dunwichamps on Wed Sep 12, 2012 12:33 pm
    Since the original thread is fairly buried and this will be my last photo post on this amp I am going to start this thread for any other discussion about this amp
    It is a guitar amp built out of the iron set for a M-125 kit. Once again I am going to thank Bob for both the opportunity to buy the iron as well as many helpful emails we have exchanged about mounting and the specs of the iron. Amp should ship soon out to customer, its been a long build. just been lately waiting on this headshell to be built. I have some final gut shots available if people want them. The big circular cutout on the back is where a fan will be installed. Wrapping that up this weekend.
    Re: Guitar Amp Built out of M-125 Iron Set
    Post by tubes4hifi on Wed Sep 12, 2012 1:48 pm
    nicely done!
    dunwichamps
    Post by dunwichamps on Wed Sep 12, 2012 1:50 pm
    tubes4hifi wrote:nicely done!
    thank u!
    I also believe a thanks to you is in order as I believe you are also in charge of the kits. Correct me if I am wrong.
    Post by Bob Latino on Wed Sep 12, 2012 3:29 pm
    Hi Nick,
    Looks nice ...
    How did your guitar amp work out with respect to power, the "guitar sound" etc? I ask the question because the M-125 output transformers were interleaved/layered wound with M6 laminations and designed basically for a wideband audio hi-fi amp. You are the first (and I believe the only) person ever to use that transformer pair for a guitar amp.
    dunwichamps
    Post by dunwichamps on Wed Sep 12, 2012 3:33 pm
    for the kind of guitar sounds the user is going for, a hifi, large power/frequency bandwidth approach is quite apt. He is generally looking for an extremely clean amp with large headroom which he can layer on effects pedals to achieve desired distortion and other types of guitar effects. The extra bandwidth is very nice for achieving good low end response when you push the amp into overdrive and push the power beyond normal hifi expectations. Of course as we push the output further we reduce bandwidth but that is to be expected. I should mention I allow the user to switch between UL and Pentode operation where Pentode operation will increase output power with added THD, something that is not a problem for guitar sound. I was quite impressed with the M-125 iron, it does not increase in temperature too much even during heavy duty cycles at high output power.
    there actually is precedent for using hifi based designs for guitar and bass. the Sunn amp company started out taking Dynaco amps and just converting them to be used for guitar and bass. The designs slightly modded the preamp to include EQ controls but the power amps are direct or near clones of dynaco kits using dynaco iron. they had 2 x EL34, 2 x Kt88 and I believe 4 x Kt88 amps al[l based on Dynaco stuff.
    dunwichamps
    Post by dunwichamps on Thu Sep 13, 2012 10:02 am
    costerdock
    Post by costerdock on Thu Sep 13, 2012 3:34 pm
    Man that came out really nice - I've been following both threads on this - great work.
    dunwichamps
    Post by dunwichamps on Thu Sep 13, 2012 6:15 pm
    thank you!
    DarthBubba
    Post by DarthBubba on Sat Sep 15, 2012 7:13 pm
    dunwichamps wrote:Here is a nice hires gutshot
    http://img38.imageshack.us/img38/7584/img1494bx.jpg
    Beautiful handiwork. Others should look at this picture a long time and aspire to that level of workmanship.
    Simply gorgeous.
    -DB
    dunwichamps
    Post by dunwichamps on Mon Sep 17, 2012 5:23 pm
    Simply gorgeous.
    -DB
    thank you!
    mantha3
    Post by mantha3 on Fri Sep 21, 2012 4:09 pm
    WOW! Hell of a good job with the wood work as well!!!
    R U building the speakers too? Post the whole stack if you are when done if you can.
    Excellent!
    dunwichamps
    Post by dunwichamps on Fri Sep 21, 2012 4:21 pm
    I dont build the speaker cabs or speakers but this is what is looks like on my 4x12 cabinet (read 4 12" speakers)
    The guitar is a custom made piece by a local builder, its a baritone, or a low tuned guitar. about 4 steps down from a standard E tuned guitar. The scale is extended to compensate for that low of a tuning.
    Heres the cover
    dunwichamps
    Post by dunwichamps on Sat Sep 22, 2012 9:41 am
    A youtube demo of this. It ships to customer today
    http://www.youtube.com/watch?feature=player_embedded&v=tnDXEiXVAL4
    mantha3
    Post by mantha3 on Sat Sep 22, 2012 11:46 am
    Look at the head on that!
    Killer combo. Well done my man
      Current date/time is Wed Jan 17, 2018 4:39 am
