    Replacing 50/50 can with 4x30mfd can cap in a SCA-35
    kens770
    Post by kens770 on Fri Sep 14, 2012 12:07 pm
    I was told the original 50/50 cap for the SCA-35 was no longer available and to use the 30/30/30/30 from Tubesandmore.com and wire it to get 60/60. I order the cap but wanting to be sure I wire it correctly.
    Each of the terminals on the bottom are the + side of the cap and the case is -.
    To wire it in parallel I would need to jumper two 30mfd terminals together. Is the right?
    If I am wrong please will someone tell me how to wire each pair of 30/30 mfd caps in parallel to get 60mfd.
    anbitet66
    Re: Replacing 50/50 can with 4x30mfd can cap in a SCA-35
    Post by anbitet66 on Fri Sep 14, 2012 12:56 pm
    You are correct. Pick two terminals and jumper them together. 30uF+30uF=60uF. Tony
      Current date/time is Mon Jun 25, 2018 3:15 pm
