    Resistor Working Voltage
    turbodan
    Resistor Working Voltage Empty Resistor Working Voltage
    Post by turbodan Fri Jul 06, 2012 3:39 pm
    Hi All,
    I just purchased a bunch of Dale metal film resistors for a new PAS-3X build I am doing (PC5 and PC6 Boards). I see they have a maximum working voltage of 250V, and was wondering if they would see anything like this in operation. I assume the 100K plate loads would be the most probable location for a high voltage across the resistor, but just want to make sure. Should I go ahead and use them, or try to find some higher rated parts? Let me know what you think.
    Thanks!
    hawaii.ken
    hawaii.ken
    Resistor Working Voltage Empty Re: Resistor Working Voltage
    Post by hawaii.ken Fri Jul 06, 2012 4:19 pm
    May I ask what boards/mods are you using? Pictures would be great also!
    Original design voltage for PC-5 is 210v and 330v for PC-6 so your Dale metal film resistors should be OK.
    turbodan
    Post by turbodan Fri Jul 06, 2012 5:31 pm
    hawaii.ken wrote:May I ask what boards/mods are you using? Pictures would be great also!
    Hi Ken,
    I have been lucky enough to get a brand new unassembled kit from a friend, the only problem is the PC5 board is missing. Everything is still in the original packaging, even the pots are in their Centralab cardboard wrapper. I don't have any pics of it yet, but I will be sure to take some as this seems like a somewhat rare find to me.
    I am curious to hear what the original sound was like, so I purchased a reproduction PC5 board and used the layout thread on this forum to decide what values to buy. That being said however, I am a big believer in beefing up the power supply, so I did purchase a PAS Regulator Board from Classic Valve Design. The only other modification I plan on making is implementing the RIAA correction on the PC6 board, so I can wire the selector switch for more line level inputs, as I have many devices that are line level.
    -Dan-
    hawaii.ken
    hawaii.ken
    Post by hawaii.ken Fri Jul 06, 2012 8:27 pm
    Hi Dan
    Note that I have mixed up the two boards in my previous post. Original design voltage for PC-6 is 210v and for PC-5 its 330v.
    Did your unassembled kit come with the original Dynaco labeled Telefunken tubes?
    I am still in the middle of modding my PAS-2 with boards (PAS-K and regulator) from Classic Valve Design. Before I started my mods I spent almost a month rolling tubes thru the PAS-2 with the original boards and build. The Telefunken tubes won hands down.
    turbodan
    Post by turbodan Fri Jul 06, 2012 9:23 pm
    hawaii.ken wrote:Hi Dan
    Yes, though they are labeled Telefunken and no mention of Dynaco. The 12X4 is labeled with Dynaco. From what I gather this kit was very late production, the PC6 I have is fiberglass board style, so maybe that has something to do with it.
    turbodan
    Post by turbodan Thu Nov 01, 2012 10:08 pm
    Finally, here are some pictures:
    The tube boxes
    Resistor Working Voltage IMG_1691
    The tubes themselves (all are the same)
    Resistor Working Voltage IMG_1759
    More on the build to come soon...
    -Dan
    Post by Roy Mottram Sat Nov 03, 2012 8:04 pm
    no resistor in a PAS3 has more than 160v across it. Most 1/2 watt resistors are rated at 350v, and 1/4 watt resistors are rated at 250v.
    The 100K plate resistors on the PC5 board should be rated at 1 watt, as it actually dissapates .17w, a little high for a 1/2 watt if you want it to last several years.
      Current date/time is Thu Apr 18, 2024 11:48 pm
