    PAS3 cap question
    stellan
    PAS3 cap question
    Post by stellan on Sun Nov 11, 2012 4:46 pm
    On the board layout for the PC5 line stage there are two 3900pF caps. Does anyone know if it´s OK to use 4700pf instead or is this a critical value?
    Stellan
    Re: PAS3 cap question
    Post by tubes4hifi on Tue Nov 13, 2012 4:51 pm
    that's part of the high-filter circuit, so it will affect the freq response when the switch is in the high-filter position,
    which rolls off the upper frequencies. Original Dynaco value was 4000pf. 3900pf is closest standard value.
    Or even use 3300pf and 680pf in parallel. It shouldn't make any difference in normal use without the high-filter switch.
      Current date/time is Thu May 24, 2018 7:50 am
