    recommend me some tubes.
    gatchaman
    recommend me some tubes. Empty recommend me some tubes.
    Post by gatchaman on Sun Nov 18, 2012 3:06 am
    Hi everyone, I have a PAS 2 and a ST-35. I want to start upgrading both with new tubes, cause the old ones need to be replaced. I was wondering, what are your thoughts/experiences with tubes to bring these two to live again?. I am new to tuberolling so please help me out.
    Thanx in advance.
    recommend me some tubes. Empty Re: recommend me some tubes.
    Post by Guest on Sun Nov 18, 2012 9:37 am
    Hit Jim McShane up for a quad of 6P14P-EB's. He does a great job of matching them. Not too many choices for input tubes. I use JJ.
    Oooops, I just noted that you were in Holland. Maybe you can source something there.
    Tiziano73
    Tiziano73
    recommend me some tubes. Empty Matching Tubes
    Post by Tiziano73 on Mon Nov 19, 2012 7:19 am
    Hi gatchaman
    In my experience, i prefer NOS Telefunken or Dynaco 12ax7 (are the same) for PAS but i know that are very expensive to find matched.
    Anyway any brand you will choose remember to buy a matched and balanced pair.
    Some info on triode here:
    http://www.tubeaudiostore.com/tubmatdem.html
    I hope this help.
    Tiziano
    DynakitParts
    DynakitParts
    recommend me some tubes. Empty ST-35 tube choices
    Post by DynakitParts on Mon Nov 19, 2012 8:11 am
    Regarding the ST-35...I would suggest the Sovtek EL84M output tubes. These should
    be ordered as a matched quartet. The "M" some say stands for Military, however the
    construction is more robust as compared to Sovtek's standard EL84. The ST-35 is hard
    on output tubes so this would be a good choice for this amplifier. As far as the (2)
    7247 input tubes...For new production tubes I have had good results with the JJ brand
    and for NOS...Almost any USA or Euro brand should work well. These (2) tubes do not
    need to be matched.
    The 7247 tube is also designated as "12DW7" & "ECC832"
    Kevin
    gatchaman
    Post by gatchaman on Mon Nov 19, 2012 1:09 pm
    Thanx for the suggestions everyone. I seem to have trouble finding the 12X4 tube for my PAS2. Any suggestions?
    Tiziano73
    Tiziano73
    Post by Tiziano73 on Mon Nov 19, 2012 1:54 pm
    yes
    you have trouble because you need 12ax7 for preamp tubes or 12x4 for rectifier tube Smile you write 12ax4 !!! Smile.
    For 12x4 rectifier tube, you can search on ebay or here for example:
    http://tubedepot.com/nos-12x4.html
    regards
    Tiziano
      Current date/time is Sat Feb 22, 2020 1:41 pm
