    Initial Power-On Procedure
    Yvon Massicotte
    Post by Yvon Massicotte on Thu Jan 17, 2013 4:26 pm
    I've just finished building my ST-70 with the VTA board (low gain version).
    I build the amp from scratch using an unbuilt kit from the early sixties and the VTA board. I tested the output transformers beforehand but not the power transformer. So, I have no idea on how the components will react; they are new but 50 years old!
    I intend to proceed step by step in turning this amp on to avoid any catastrophic failure. These are the steps:
    .- pulling out all tubes, connect resistance loads, check the AC voltages at the different secondaries of the power transformer: the B+ one, the filament ones;
    .- if the power transformer is working fine, then I will insert the rectifier tube and check the DC voltages and inspect their forms on a scope;
    .- only then, if the values seem on range, I would insert one set of output tubes and check and adjust roughly the bias; I will do the same for the other channel;
    .- I will next insert the 3 driver tubes and, after appropriate warmup time fine-tune the bias;
    .- I will proceed to the AC balance test;
    .- I will again check voltages and finally I will inject a 1000 Hz signal and check for clipping on a scope.
    Have I forgotten something here or am I doing a useless or much worse a harmful procedure ?
    I would appreciate your feedback
    Yvon
    Re: Initial Power-On Procedure
    Post by peterh on Thu Jan 17, 2013 4:58 pm
    Connect power resistors as speaker load ( unless that is what you mentioned with
    "connect resistance loads," ).
    If the electrolyte capacitor is 50 years old i would suggest you start with slowly
    charging it with an external source ( increase 50V a time, allow current to diminish, then
    increase 50V again. ). Or you may start with a fresh one .. Otherwize it sound to be a good plan.
    Yvon Massicotte
    Post by Yvon Massicotte on Thu Jan 17, 2013 11:09 pm
    Dear Peterh:
    The resistance loads that I mentioned are indeed power resistors (Dale 8ohms 250 W). The QUAD capacitor is also new one bought with the VTA board.
    I appreciate you input.
    Best regards,
    Yvon
      Current date/time is Sun May 27, 2018 12:00 pm
