Need a little advice.
As you can see in the pic, I have the SP 14 on top of the PH 14 with an old Audio Control EQ on top of the SP 14 (but not covering the entire top).
I plan on replacing the Audio Control EQ with a larger Teac (EQA-180). I'll have to remove the spacers (but NOT the SP 14 rubber feet) under the SP 14 and the Teac will sit over the entire top of the SP 14.
Do you think there will still be enough room to keep the pre amps safely cool?
They don't put out a huge amount of heat but the SP does have four 6SN7s inside. Thanks for the help.
