    Alternate Power Supply for PAS 3X
    TN Allen
    Alternate Power Supply for PAS 3X Empty Alternate Power Supply for PAS 3X
    Post by TN Allen Sat Mar 02, 2013 12:05 pm
    I'm curious about alternate power supplies for the PAS 3X using the tubes4hifi TCLA line, and phono upgrade boards. I've looked at the tubes4hifi offerings, and the Triode board as well as a new transformer, which seems to be adequate for only 4 12AX7 tubes. but am curious about others, including solid state.
    I'd appreciate any suggestions.
    poconoman
    poconoman
    Alternate Power Supply for PAS 3X Empty Re: Alternate Power Supply for PAS 3X
    Post by poconoman Sun Mar 03, 2013 6:10 pm
    TN Allen wrote:I'm curious about alternate power supplies for the PAS 3X using the tubes4hifi TCLA line, and phono upgrade boards. I've looked at the tubes4hifi offerings, and the Triode board as well as a new transformer, which seems to be adequate for only 4 12AX7 tubes. but am curious about others, including solid state.
    I'm installing a power supply and RCA in/out board from here. http://home.comcast.net/~netminer/PAS-3.html
    Upgrade transformer from Dynaparts.com
    Great people. cheers
    hawaii.ken
    hawaii.ken
    Post by hawaii.ken Sun Mar 03, 2013 7:21 pm
    I'm using the "PAS Preamplifier Regulated Power PCB" from Classic Valve
    TN Allen
    Post by TN Allen Sun Mar 03, 2013 8:33 pm
    Thank you. Are you using these upgrades with the tubes4hifi TCLA and phono upgrade boards? And, if I may ask, why did you choose these?
    hawaii.ken
    hawaii.ken
    Post by hawaii.ken Sun Mar 03, 2013 10:45 pm
    I chose to use the CV PAS upgrades primarily because their documentation was readily available.
    The PAS transformer was designed to handle the current requirements for 4 tubes. Most of the phono+line preamp designs I see use 6-7 tubes. You can "get by" with running 6 tubes on the original trans but overheating becomes a concern. I opted to use a regulated supply and an after-market transformer.
    Tubes4hifi also makes a regulated supply for the PAS (transformers included) if you're not adverse to drilling mounting holes.
    kygeezer
    Alternate Power Supply for PAS 3X Empty PAS3 power supply
    Post by kygeezer Mon Mar 04, 2013 9:57 am
    I have upgraded my PAS 3 with the TCLA board, the PH 10 phono board and the Regulated Power Supply, all from Tubes4hifi. I couldn't be happier! In addition to the quality of these boards, the individual help from Roy has been invaluable. I doubt that you would get the same level of knowledgeable support anywhere else. You can get by with drilling only a couple of holes - less than 5 minutes work. The new power supply runs cooler and eliminated my concern about overloading the old transformer. The new supply has two transformers. One for filaments and one for high voltage
    Post by Roy Mottram Thu Mar 07, 2013 10:44 pm
    KYGEEZER is the man!   anyone who wants an upgraded PAS3 should look at these latest 3 upgrades, for the ultimate PAS3 preamp!
    The new power supply is simple, easy to install, works great!  The AIKIDO line stage, nothing better anywhere.
    Same with the PH10 phono section, nothing better anywhere.   What can I say?  Try it - you'll be happy!  Very Happy
      Current date/time is Fri Mar 29, 2024 4:29 am
