Hey Guys, At what sould I set the bias on the 6CA7EH (new) quad of outpur tubes? I have the VTA-70 "low gain board" AND when rolling the driver tubes, do I need to re-bias the output tubes each time I swap a 12AU7 etc...?
Thanks, Ron
Thanks, Ron
6CA7 is very similar to el-34 , 40mA ( which is 0.4V in the testpoint(s))Bigron865 wrote:Hey Guys, At what sould I set the bias on the 6CA7EH (new) quad of outpur tubes? I have the VTA-70 "low gain board" AND when rolling the driver tubes, do I need to re-bias the output tubes each time I swap a 12AU7 etc...?
Thanks, Ron
The Triode Electronics kit uses a common 10ohm cathode resistor for two output tubes. 1-volt across 10ohms gives you 100ma for 2 tubes so 50ma per tube. It's a little high. 40-45ma per 6CA7 won't change the sound but it will lengthen your tube's life.AMCjeep wrote:my instruction manual says to set the bias at 1.0 vdc. Thats a huge difference from the abovd posts. Any ideas?
AMCjeep wrote:So what would do you think is a better sounding tube KT77's or 6CA7's? I keep going back and forth on which to get, any opinions? Or is there even something better to consider like a better EL34 or different tube altogether for a ST70?
hawaii.ken wrote:The Triode Electronics kit uses a common 10ohm cathode resistor for two output tubes. 1-volt across 10ohms gives you 100ma for 2 tubes so 50ma per tube. It's a little high. 40-45ma per 6CA7 won't change the sound but it will lengthen your tube's life.AMCjeep wrote:my instruction manual says to set the bias at 1.0 vdc. Thats a huge difference from the abovd posts. Any ideas?
