    Source for new, upgraded selector switch for PAS3 upgade
    Source for new, upgraded selector switch for PAS3 upgade  Empty Source for new, upgraded selector switch for PAS3 upgade
    Post by Elrick Fri May 03, 2013 1:36 pm
    I'm in the process assembling a revamped PAS3. Purchased the tubes4hifi Regulated PS, Aikido and PH10 boards and now conclude that if I'm going to all the cost and trouble I might as well loose the original selector switch assembly along with the wafer contacts. Trouble is I'm not sure where to source a new selector switch as seen on the tubes4hifi products. Anyone have any links to the correct switch? Thanks.
    Edit: I think I see what I'm looking for on the tubes4hifi web site.
    Luddite
    Luddite
    Source for new, upgraded selector switch for PAS3 upgade  Empty Re: Source for new, upgraded selector switch for PAS3 upgade
    Post by Luddite Fri May 03, 2013 2:13 pm
    Elrick wrote:I'm in the process assembling a revamped PAS3. Purchased the tubes4hifi Regulated PS, Aikido and PH10 boards and now conclude that if I'm going to all the cost and trouble I might as well loose the original selector switch assembly along with the wafer contacts. Trouble is I'm not sure where to source a new selector switch as seen on the tubes4hifi products. Anyone have any links to the correct switch? Thanks.
    Roy has the selector switches for sale at his website (item# 4) http://www.tubes4hifi.com/PAS3-CAT.htm
    Best Regards,
    Charlie
      Current date/time is Fri Apr 19, 2024 1:24 am
