Streaming 16/44 over Qobuz, and hires through my MacBook Air, unplugged from wall while listening.
I wish you all could hear this!!!!
Bill
audiobill wrote:There are very apparent differences among dacs, from the implementation of the chip, to the critical analog stage as well as filters.
"mere dac" .
Me thinks not!
audiobill wrote:That's a personal value judgement, not a conclusion of facts.
Best,
Bill
audiobill wrote:Sorry.
No harm intended, but I have spent a lot of time on this, and wanted you to benefit!
Tom wrote:Dang, for a minute there I though Bob was going to need to get the attack cat out for you two...
MontanaWay wrote:I just ordered the TubeMagic D2, which is actually cheaper then the V90-DAC.
From what I have read, I am confident that for my use the D2 will be more than sufficient and I prefer the look of the black than the silver
I just can't see nor justify paying thousands for a mere DAC. The average human ear, in my opinion, although very good, just would not be able to tell the difference between a unit costing thousands compared to a few hundred, no matter what some people claim.
sKiZo wrote:MontanaWay wrote:I just ordered the TubeMagic D2, which is actually cheaper then the V90-DAC.
You cheap bastid!
(welcome to the club)
Consensus is, the Mavericks perform well above their price point. I think you're gonna like what you hear. I was tempted when the D2 came out, but didn't want to lose the analog in of the D1 and D1+. I run my turntable into that via an external stage to take advantage of the tooby pre-stage. Trade off is, the D2 has a much improved optical stage (which I don't use). Seems to me they both have the same USB handling, but don't quote me on that.
The volume control is bypassed by default to minimize the signal path. If you decide somewhere down the way you want the volume control for line out, I believe the D2 has the same internal jumpers as the D1+. I've done that on mine, and haven't noticed any earth shattering difference in sound quality ...
Just move those to where they aren't, and the pot works for both headphones AND line level. I find it kinda handy for loading the ST120 - What seems to work best for me is -3db from the server, down three notches on the Maverick, and volume controls on the ST120 set to around 7½ of 10. Definite difference in detail from just using any one set of controls.
Didja get the tube and op amp upgrades? I put the money I saved not going with a PWDII into tubes ... somebody stops me!!
PS ... only complaint I had with the Mavericks is the cover is dang near impossible to get off. That sucker is TIGHT! Solution was to dremel off the bottom flanges so I can just drop it on, rather than using a very large hammer or press to "slip" it on ...
MontanaWay wrote:
cheap is good....cheap rules...to a point of course!
I did mull over the analog in.......I am happy with my SP9/PH10 setup, plus I have a separate headphone amp, so the DAC is purely so that we can listen to the iPod and run the TV via optical through the system.
I did not go for any upgrades, I can always buy different tubes and op-amp if I think it is worth it or I get the tube & op-amp rolling itch
It will be nice to be able to run those few extra gadgets through our system.
