    how to bias my tubes on a ST70 without any biasing points?
    triotary
    how to bias my tubes on a ST70 without any biasing points? Empty how to bias my tubes on a ST70 without any biasing points?
    Post by triotary Mon Jun 24, 2013 4:06 am
    Hi Guys,
    I'm new to this forum. Recently got myself a rebuilt ST70 with the older VTA driver board (non CCS) and TriodeElectronics Power Supply board. I need to bias my EL34 tubes, however I'm facing a problem.
    My ST70 does not come with the dual front biasing socket. Where am I suppose probe my positive pin of my multimeter to measure the DC voltage?
    Many thanks in advance!
    triotary
    how to bias my tubes on a ST70 without any biasing points? Empty Re: how to bias my tubes on a ST70 without any biasing points?
    Post by triotary Mon Jun 24, 2013 4:09 am
    I did read up a few diagrams and instructions, from my understanding, am I suppose to probe on pin #8 of each output tube?
    Post by Bob Latino Mon Jun 24, 2013 6:39 am
      If you don't have any place to measure bias on the outside of the chassis then you have to open the amp up. Measure the bias from pin 8 to chassis ground on each output tube. Use the 0 to 2 volt DC scale on your meter. For EL34 output tubes set each tube to .400 DC. That is POINT 4 volts DC which is 4/10 of a volt.
    Post by peterh Mon Jun 24, 2013 6:59 am
    triotary wrote:I did read up a few diagrams and instructions, from my understanding, am I suppose to probe on pin #8 of each output tube?
    Yes. But you will have to figure out q few things :
    - is each channel using a common catode resistor ?
    - how large is that resistor
    Depending on your findings you will have to calculate the voltage across the resistor.
    Dynaco stock used a 15.6 ohm resistor common to both tubes in each channel, the
    recommended voltage is 1.56V which will give 50mA / tube.
    More modern gear might have a different value, and the current wizdom
    is to use 40mA / tube as a startingpoint.
    Finally: if you don't have any measuring connections outside i would recomment that you create one.
    Post by Bob Latino Mon Jun 24, 2013 7:05 am
    The original poster mentioned that this amp had a VTA driver board. I can check with Roy but AFAIK the VTA driver board always used a fixed (adjustable) bias system with a 10 ohm bias resistor on each output tube.
    Post by peterh Mon Jun 24, 2013 7:49 am
    the VTA driver boaard has no 10ohm resistor, they are mounted on the tube sockets.
    Post by Bob Latino Mon Jun 24, 2013 7:53 am
    Peter,
      I mentioned in the post that the VTA driver board had a 10 ohm bias resistor "on each output tube".  I never mentioned or inplied that the 10 ohm bias resistor was on the driver board ..
    Post by Roy Mottram Mon Jun 24, 2013 11:34 am
    gee guys, let Triotary figure it out.   resistance from pin 8 on each output tube to ground.   If it's a VTA mod, it's 10 ohms.
    You want 40ma of bias.   Ohm's Law, anybody heard of that?   0.40vdc across each resistor
    Post by sKiZo Mon Jun 24, 2013 11:58 am
    oooooOOOOOooooooohhhhhhmmmmMMMmmm ...
    Sounds like time for a circuit mod. OP's gotta get inside anyway, right?
    Easy enough to add bias test points - I found some nice ones at Weber's online store when I went in to get my Copper Cap. Anybody got the exact step by step for that specific model to make it happen? Make for a nice sticky too ...
    Weber's website is kinda hard to navigate ... just stumbled across these myself, so here's a link:
    https://taweber.powweb.com/store/plugord.htm
    They've got all sorts of neat stuff buried here and there ... bit of a treasure hunt though.
    Post by Roy Mottram Mon Jun 24, 2013 10:50 pm
    instructions for tip jacks - connect the center hot lead to pin 8 (one for each output tube)
    connect the outer ground lead to chassis ground
    there 'ya go, step-by-step
    Post by sKiZo Tue Jun 25, 2013 1:14 pm
    I was hoping for something simpler ... got any pictures? tongue
    triotary
    Post by triotary Tue Jun 25, 2013 10:54 pm
    Thank you all! Really appreciated! Yes the Amp comes with an older version of VTA board without the CCS. It did fired up well and managed to drive a pair of 15" tannoy berkeley very well, with the help of a Marantz 7C. Now I will go ahead and bias the tubes from pin 8 of each EL34 output tubes.
    Yes, i was also hoping that I could bias the tubes while probing some points of the VTA board ^_^"
      Current date/time is Thu Mar 28, 2024 4:59 am
