    Z-mod power supply question
    Babgrip
    Post by Babgrip on Fri Jul 12, 2013 6:31 pm
    What is the correct fuse for the Pas2/3 Z-mod power supply ,it came with a 1 amp fast-blow. I can not use aux outlets the fuse will blow. Would it be safe to use a 3 amp fuse. I would like to have ST-70 and Turntable switched by pre-amp.
    2nd question with the upgraded power supply is it ok to use 120v or is the stock transformer designed for 115-117v
      Current date/time is Tue May 22, 2018 9:31 pm
