I've seen on different tube amps, along with my guitar amp, a Standby switch. Is there any benefit to installing one on a ST-120? What would it involve to install one?
Standby switch for ST-120
Re: Standby switch for ST-120
THOR-IUM wrote:I've seen on different tube amps, along with my guitar amp, a Standby switch. Is there any benefit to installing one on a ST-120? What would it involve to install one?
If you use a GZ34 rectifier or a Weber Copper cap solid state rectifier on the ST-120 or any tube amplifier then a standby switch is not really needed. A GZ34 has an indirectly heated filament which gives a 15 second or so "warm-up standby" built into the tube before high voltage is applied. The Weber Copper Cap has a shorter 3 or 4 second built in warm-up before high voltage is applied. I have used a Weber Copper cap (model WZ68) in my own ST-120 for almost 2 years and it has held up fine and gives a higher B+ DC high voltage than any tube rectifier AND doesn't "sag" the high voltage as much as a tube rectifier at higher volume levels.
Where a standby switch may be useful is in a tube amp with a solid state rectifier "hard wired" into the amp. The Dynaco ST-35 and Dynaco SCA-35 are two such amps. The fact that many of these amps are still around and working fine after 40 + years WITHOUT any standby switch shows that the "need" for a standby switch on amps like these may be somewhat overstated.
