    preamp/amp impedance interface
    preamp/amp impedance interface Empty preamp/amp impedance interface
    Post by Guest Sun Jul 21, 2013 3:38 pm
    It seems that a minimum 1:10 ratio of preamp output impedance to amp input impedance is desirable. The Dynaco ST-35 has a whopping 500,000 ohms input impedance and I'm using a phono stage (with a volume pot) that has 450 ohms @ 1kHz output impedance. That's a ratio of over 1:1000.
    Is this okay?
    preamp/amp impedance interface Empty Re: preamp/amp impedance interface
    Post by Roy Mottram Sun Jul 21, 2013 3:53 pm
    certainly OK, fantastic!
    Post by sKiZo Sun Jul 21, 2013 7:54 pm
    Does it work for ya?
    [Check]
    It's good then!! tongue
    I'm told I'm crazy to be using the .75ma setting on my McIntosh MC2205 when driving it with a Sansui quad. "Normal" people use the 2.5ma input. But ... although I do get a more civilized ratio of volume to control settings, I also lose a lot of crispness and detail.
    If you think there's an issue and would like to experiment, you can always get a good 50k pot and put that inline with a chopped RCA cable to adjust the line level input to the amp. If that makes a difference, then you can think about do an output mod on the pre ... probably just a simple resistor swap.
    I ran into a situation on my Oppo SACD ... wanted to drive a center channel speaker and had an old Carver cube ... VERY LOUD and that can be dangerous at a couple hundred watts. Did the split cable thing and just tapped a hole in an old lunch size applesauce cup for a "custom case". Works great, and been like that for years ... keep thinking I should improve on the case, but ... why fix what ain't broke? It DOES have a really nice knob. tongue
    (and ya ... they ARE all right about the crazy part) geek
    Post by arledgsc Mon Jul 22, 2013 11:03 am
    For voltage transfer it is ideal to have low output impedance and high input impedance.   Otherwise you get into voltage divider issues so 1:10 (or higher) is a good rule of thumb.   For example if you have 1:2 impedance ratio the amp input would only see 2/3 of the preamp's output.   1:10 ratio sees 91% voltage transfer.   1:1000 sees 99.9% transfer.  Vin = Vout x ( Zin/(Zin + Zout) ).   You also get into frequency response issues as well with narrowing impedance ratios.   And a variable attenuator on the amp's input changes the input impedance - usually by lowering it.
    Just for clarification, maximum power transfer is always best with matched 1:1 impedances as in output transformers and speakers.  We are only dealing though with voltage gains in the preamp/amp interface.
    Jim McShane
    Post by Jim McShane Mon Jul 22, 2013 11:50 am
    arledgsc wrote:For voltage transfer it is ideal to have low output impedance and high input impedance.   Otherwise you get into voltage divider issues so 1:10 (or higher) is a good rule of thumb.   For example if you have 1:2 impedance ratio the amp input would only see 2/3 of the preamp's output.   1:10 ratio sees 91% voltage transfer.   1:1000 sees 99.9% transfer.  Vin = Vout x ( Zin/(Zin + Zout) ).   You also get into frequency response issues as well with narrowing impedance ratios.   And a variable attenuator on the amp's input changes the input impedance - usually by lowering it.
    Great post! Thanks.
    People following this thread should also keep in mind two things about the high input impedance of the amp in this equation:
    1. The higher input impedance means less current is needed from the preamp's output. This is good.
    2. The higher the input impedance of the amp the more sensitive it can be to noise pickup. This is bad.
    So it's always a compromise, but as the post above states so clearly - for voltage transfer you must be sure the impedance is adequately high. The 10:1 ratio works well in most cases.
    Post by arledgsc Mon Jul 22, 2013 12:53 pm
    Excellent clarifications.   Studios use 600 ohm (balanced) inputs sometimes for a reason and that is to lessen noise pickup on the inputs with long cable runs.  It is much easier to induce current in a circuit at high impedance.  So very high input impedance is not always a good thing.   So yes always a compromise.
      Current date/time is Thu Mar 28, 2024 7:49 am
