    Dynaco Pas2 tape head special removal, EQ circuit removal
    Babgrip
    Post by Babgrip on Mon Aug 26, 2013 12:14 am
    With a stock Pas2 is it possible to remove the Special,Tape head & FMa/AMb inputs. I have no desire to add any more high level inputs .Would like to replace selector switch with modern one and clean up rats nest.
    Is it possible to convert blend switch to a simple stereo/ mono switch
    I plan on leaving tone ,loudness, filter & tape/input intact.
    If I remove the selector switch are there mods need on phono PC board to eliminate EQ circuit & correct RIAA.
    I have seen Curcio's page but he is adding inputs, do not need 3 turntables or CD players .just 1 each LP,Cd, Tuner.
    I would like the end result to be basically a stock Pas minus circuits not needed today
    I should add I have replaced the boards with new stock ones from VE Does anyone know if the Riaa is already corrected or is does it truly follow original specs.
    Pillo69
    Re: Dynaco Pas2 tape head special removal, EQ circuit removal
    Post by Pillo69 on Mon Aug 26, 2013 1:01 pm
      Current date/time is Tue Feb 20, 2018 5:52 am
