    Choke vs. resistor
    Choke vs. resistor
    Post by corndog71 on Sun Sep 08, 2013 12:28 pm
    I was wondering if the chokes are particularly better than a resistor and if not what value would be ideal for the ST120?
    sailor
    Re: Choke vs. resistor
    Post by sailor on Sun Sep 08, 2013 1:31 pm
    Using chokes in a power supply preservers more of the power. Resistors burn off power to clean the signal. Resistors are a lot cheaper but I think in Amplifiers you are better off with chokes. In a preamp where you are dealing with such low mil-amps to begin with resistors make more sense. You can play with the calculators below to see exactly how LC and RC filters work.
    http://www.ampbooks.com/home/amplifier-calculators/LC-ripple-filter/
    http://www.ampbooks.com/home/amplifier-calculators/RC-ripple-filter/
      Current date/time is Thu May 24, 2018 11:13 pm
