I remember seeing somewhere a list of readings for various points on the board. Of course, I bookmarked it, and of course, lost the bookmark ...
Anyone? Seems like that would be a nice sticky ...
The check list that you mention is also in the VTA ST-120 assembly manual.sKiZo wrote:OK then ... I do remember seeing a checklist though, so if anyone runs across it ... thanx in advance.
FINALLY got around to slipping some juice to the amp ... no explosions, the fire extinguisher remains parked, and good heaters on the drivers. Joy.
Note ... I'm supposed to be seeing 6.1 - 6.5 at the driver board, but it's a steady 7.1 here. Sounds reasonable as I'm seeing almost 124vac out of the wall today. Definitely gonna have to consider running the amp full time off a variac ...
