    ST120 Test Voltages
    ST120 Test Voltages Empty ST120 Test Voltages
    Post by sKiZo on Mon Oct 07, 2013 12:22 pm
    I remember seeing somewhere a list of readings for various points on the board. Of course, I bookmarked it, and of course, lost the bookmark ...
    Anyone? Seems like that would be a nice sticky ...
    ST120 Test Voltages Empty Re: ST120 Test Voltages
    Post by Bob Latino on Mon Oct 07, 2013 1:08 pm
    Look on the schematic in you assembly manual .. There are some voltages on the schematic included in your assembly manual .. Note - those voltages are + or - 10%
    Post by sKiZo on Mon Oct 07, 2013 3:55 pm
    OK then ... I do remember seeing a checklist though, so if anyone runs across it ... thanx in advance.
    FINALLY got around to slipping some juice to the amp ... no explosions, the fire extinguisher remains parked, and good heaters on the drivers. Joy.
    Note ... I'm supposed to be seeing 6.1 - 6.5 at the driver board, but it's a steady 7.1 here. Sounds reasonable as I'm seeing almost 124vac out of the wall today. Definitely gonna have to consider running the amp full time off a variac ...
    Post by Bob Latino on Mon Oct 07, 2013 4:29 pm
    sKiZo wrote:OK then ... I do remember seeing a checklist though, so if anyone runs across it ... thanx in advance.
    The check list that you mention is also in the VTA ST-120 assembly manual.
    With 124 VAC off the mains, all your voltages will be higher than normal. If you don't use a variac (set to about 118 VAC) then you will probably have shorter than normal tube life in your amp.
      Current date/time is Fri Dec 06, 2019 7:55 am
