by sKiZo Tue Oct 15, 2013 1:52 pm
That will get you going, but I assume you also want to be able to still use the built in amp on the receiver?
In that case, just loop out with a "Y cable. Did that for years on my McIntosh amp driving it with the front channels of a Sansui quad. I originally used the cable variety "Y", but eventually went with the hard connectors ... more a bling thing than anything else ...
One cable set connects to the PRE OUT ... the other loops back to the AMP IN to complete the loop. Also works with a tape loop.
Went one step further with my shiny new ST-120 build ...
OOooh ... look! It's an "innie" !!
Same principle, only as long as I was building a custom case, I did the loop internally so all that shows is the jacks. I can still use it with a standard pre-amp ... just use one set of jacks is the only difference.
