I have rebuilt two Dynaco MK IV amps, and the one using the original transformers is running great. However, the second is giving me problems. I reused the original output transformer, but installed a new PA-135 power transformer. After playing it for a week this new PA-135 failed (shorted secondary). I replaced it with another new PA-135 and also added a CL-90 thermistor. After 10 days of (heavy) use it seems that this transformer has also failed with what I think is a shorted primary (3.7 ohms across the primary leads). Also, the thermistor is fried. The power transformer did get pretty hot to the touch. Not so hot that I couldn't keep my hand on it, but it was borderline too hot. The output transformer is original/old, as well as the 7199 and EL34s. The rectifier tube, choke, can capacitor and driver board are all new. Every resistance value I compare to the working amp approximately matches except for the pt primary resistance. Is there anything other than the power transformer being faulty that might cause this, e.g. bad output transformer, bad tube(s)?
Thanks for any help/ideas!
