    Replacing RCA Input Jack
    BNR_1
    Post by BNR_1 on Thu Dec 19, 2013 11:32 pm
    I want to change out the RCA female input jack on a Mark III amp. Does the jack required to be insulated from the chassis? A vendor has a note that the jack they sell is not insulated and is only suited for mounting on plastic or other non-conductive surfaces. But does this warning apply to the Dynaco amps?
    Re: Replacing RCA Input Jack
    Post by sKiZo on Fri Dec 20, 2013 12:36 am
    These amps isolate the ground for the audio inputs, so yes, it needs to be insulated. Probably easiest to just replace it with a similar jack already mounted on a non-conductive board.
    Bob or Roy can probably set you up with what you need ...
    BNR_1
    Post by BNR_1 on Fri Dec 20, 2013 10:38 am
    Thanks sKiZo for confirming.
      Current date/time is Thu Jan 18, 2018 3:58 pm
