    Dynaco SCA-35 help
    Babgrip
    Dynaco SCA-35 help
    Post by Babgrip on Tue Jan 14, 2014 11:14 am
    Just picked up sca35 all tubes power up except one 7199 . I have tried swapping positions ,same problem. Any ideas where to start tracing problem .
    Thank you
    Re: Dynaco SCA-35 help
    Post by peterh on Tue Jan 14, 2014 11:50 am
    What do you mean with "power up" ? Is the filament not glowing on one 7199 ?
    Is it located to the socket or does it follow the 7199 ?
    sailor
    Post by sailor on Tue Jan 14, 2014 12:27 pm
    If you mean one socket then leave the tube out and test to see if you have filament voltage. [Must test from the top to find out if it is rust inside] If you do not have voltage it must be the socket or a wire [solder joint] between the 2 boards.
    Babgrip
    Post by Babgrip on Tue Jan 14, 2014 1:33 pm
    Checked voltages at both 7199 tube sockets both check out ok. Swapped out the 12ax7's with different set of tubes . Problem solved
    Thank you for help.
    Post by sKiZo on Tue Jan 14, 2014 3:37 pm
    'Twere all life's problems be so easily solved ...
      Current date/time is Wed Jan 17, 2018 12:42 am
