Has anyone tried, or is it frowned upon, to try a 12at7 in the low gain driver board? Only reason I ask is that I have tons of these tubes, and didn't know if this were possible with this board or not. Any feedback is appreciated.
Low gain VTA70 driver board...has a 12at7 been tried?
olds442111- Posts : 8
sKiZo- Posts : 1530
Not recommended, and I'm sure Bob will be along shortly to give you a severe frowning ...
This will have to hold you for now ...
PS ... I've got some nice Amperex Holland 12AT7's here that I picked up before I got the word on the high vs low boards. Make me an offer.
or not, haha
The resistor set has been altered from the older higher gain board as opposed to the newer lower gain board to optimize the board for the lower gain 12AU7 type driver tubes. (8 resistors on each channel are different from one board to the other) The newer board also has "CCS" (a constant current source in the tail of the phase splitter). I don't recommend the use of 12AT7 driver tubes in the newer lower gain CCS board. It may work but gain will be higher and the 12AT7 tubes that you use will not be operating optimally.
Thanks Mr. Bob. Just wanted some input on it.
