    Right Angle Connectors
    Brap
    Brap
    Right Angle Connectors Empty Right Angle Connectors
    Post by Brap Thu Feb 06, 2014 6:17 pm
    Was wondering if any of you have used right angle RCA connectors to provide a bit more room in the front of either amp when running the signal input RCA cables. Or, have any of you found good quality RCA cables that have a 90 degree connector at one end? Just trying to pretty things up a bit in a new rack enclosure and still show off the beauty of an ST-70.
    Thanks!!
    ArlanB
    ArlanB
    Right Angle Connectors Empty Re: Right Angle Connectors
    Post by ArlanB Thu Feb 06, 2014 6:36 pm
    Brap,
    Have been using two pair of gold plated right angle RCA connectors to route the cables under the amp toward the back to clean up the front appearance of my VTA ST120.  They work very well.  I have not noticed any degradation in the quality of the sound.
    ArlanB.
    Post by sKiZo Thu Feb 06, 2014 6:49 pm
    What front connectors?
    Right Angle Connectors Big-bottles01
    BIFF!
    (Owwwwwwwww)
    Thanx ... I needed that ...
    Post by Guest Thu Feb 06, 2014 6:51 pm
    I use a pair of rhodium plated Cardas right angle RCA's on my amp. $26/pair.
    Post by sKiZo Thu Feb 06, 2014 7:04 pm
    Anybody ever try these?
    http://www.ebay.com/itm/88-Silver-Interconnects-Audio-CD-Player-RCA-Output-Flat-Cable-Bass-1m-3ft-/360483708204
    88% silver, and the flat cable should be pretty unobtrusive.
    The Kimber cables are also quite flexible, but maybe more so than your wallet ...
    Post by corndog71 Thu Feb 06, 2014 11:56 pm
    Brap
    Brap
    Post by Brap Fri Feb 07, 2014 10:29 am
    sKIZo -- too sweet -- that is a work of art!
    Post by sKiZo Fri Feb 07, 2014 3:31 pm
    Thank you kindly sir ... my vanity keeps looking for excuses to post up a pic here and there. clown
    Often wondered why yall couldn't put tall feet on a stock chassis and add a small box for inputs underneath. Just leave the RCA's up front to keep em guessing ...
    Anybody asks ... "What, you never heard of bluetooth?"  Cool
    Post by deepee99 Tue Feb 11, 2014 3:33 am
    corndog71 wrote:Here are some inexpensive ones.
    http://www.bluejeanscable.com/store/adapters/index.htm
    I've got two pair of the Blue Jeans 90s; one off the back of the turntable and one in the back of the phono preamp for tight spaces. They work great. Blue Jeans doesn't confuse "inexpensive" with cheap. These babies are hefty and have a gentlemanly firm grip. If lightning can travel at right angles, phono signal electrons probably can, too.
      Current date/time is Fri Apr 26, 2024 12:19 pm
