Everybody is out of stock on these, where can I get one ASAP???
80+40+30+20@525v Cap Where can I get One????
If you can't get the CE 525 volt 80, 40, 30, 20 quad cap you can get the 550 volt F&T 80, 40, 30, 20 quad cap from Dynakitparts. It has the same symbol markings as the CE cap except the CE cap has one lug with no symbol which on the F&T cap is a round symbol. The Dynakitparts quad cap is about $13 more than the CE cap but is rated 25 volts higher.
Dynakitparts 550 volt quad cap
arkivel- Posts: 6
Hi Bob.
Is the extra 25 volt cushion really needed for the ST70, mark II, or mark IV? Will it make a difference in these amps?
I need three Quad caps and $18 per unit starts to add up after xmas.
thanks
thanks
arkivel wrote:Hi Bob.
thanks
You will probably have to go with the Dynakitparts cap anyhow because the CE Distribution 80, 40, 30, 20 cap is out of production right now and not available. I think CE is changing over to new machinary or changing the site of production of their quad caps. I am not sure exactly why they are not available right now?
Mark Korda- Posts: 19
80/40/30/20 Caps
Hi Tanner,I saw a new one made just for the Mark 3 on Ebay.Mundorf from Germany is producing them.I went further and got the address(CTech Electronics)(ctech@cteche.com)their phone # is 301-351-3781...let me know if this helps you out...sincerely Mark Korda(mark.korda@myfairpoint.net)
Mark Korda wrote:Hi Tanner,I saw a new one made just for the Mark 3 on Ebay.Mundorf from Germany is producing them.I went further and got the address(CTech Electronics)(ctech@cteche.com)their phone # is 301-351-3781...let me know if this helps you out...sincerely Mark Korda(mark.korda@myfairpoint.net)
Hi Mark,
That Ctech ($75!) 80, 40, 30, 20 @ 550 volt quad cap is an "Authenticap" made by F&T (Fischer & Tausche) in Germany and it is the SAME cap that Dynakitparts sells for $52.50. I know that for a fact. I do not believe that Mundorf makes any quad caps. I talk to Kevin at Dynakitparts from time to time. He mentioned to me that he regretted raising the price from $49.95 to $52.50 on the F&T made quad cap but the exchange rate between the German Mark and the US dollar has changed with the dollar being devalued.
- Post n°7
80/40/30/20 Caps
Thanks for the info Bob and Tanner,for my ST-35,I found the electrolytic cap at Zack Engineering(Vibroworld.com)I checked and did not see one for a Mark 3.They had ones for the ST-70 though.I did see one at 80/40/20/20/but it was only rated for 450 volts.They did say they would make custom orders.Maybe if you wrote them and described to them that there would be a lot more people needing them,well who knows.Mark K.
DynakitParts- Admin
- Post n°8
80-40-30-20 @ 525 vdc can caps
Hi Mark,
Zack Engineering "Vibroworld.com" has been closed for nearly
one (1) year. When was the last time you visited their Website?
Kevin @ Dynakit
Kevin @ Dynakit
- Post n°9
80/40/30/20 Caps
Hi Kevin,I was on line looking at the Zach Engineering site yesterday Jan 2.I didn't know they were closed..Mark K.
Clik2media- Posts: 40
I have a couple CE cans spare, how many do you want.
I can mail one out for $42.00 to Continetal US.
thnx -
thnx -
