    Is failure imminent?
    frank
    frank
    Is failure imminent? Empty Is failure imminent?
    Post by frank Fri Mar 28, 2014 4:19 pm
    I was listening two days ago. All of a sudden there was snap, crackle, and pop in one channel. It continued regardless of volume. I turned the amp off, waited a few minutes, then turned it back on. After two full days of constant use, there has not been a repeat of the noise.
    Capacitor going bad somewhere?
    Is failure imminent? Empty Re: Is failure imminent?
    Post by Bob Latino Fri Mar 28, 2014 4:35 pm
    What you describe is more likely to be a tube issue .. an output tube on that channel or one of the driver tubes that feed that channel ..
    frank
    frank
    Post by frank Fri Mar 28, 2014 4:56 pm
    Thanks, Bob. So, I swapped all tubes L+R. I'll wait to see if/when the noise recurs, then swap drivers.
      Current date/time is Fri Apr 19, 2024 12:44 pm
