The size I'm looking for is about 0.5" outer dia, about 0.185" hole dia and about 0.1" thick. Can be a little thicker and the outer dia can also be little larger, either in black or brown.
Can anybody please point me to a supplier, thanks.
sKiZo wrote:Another option is to oversize the mounting holes a bit and use grommets.
I went with an oversized hole (10mm or thereabouts if I remember right) , an 00 washer between the transformer and chassis plate, and a 1/4" beveled washer underneath, bevel side in, with a flat meta washer between that and the nut. When compressed the two rubber washers actually touch each other, centering the bolt in the hole and preventing any chance of metal to metal contact.
Also available at the local hardware in the plumbing section.
Bit overkill, but I also added a thin nylon washer at the head end of each screw AND did a layer of heat shrink on the threads inside the iron. Just razor it off a bit proud of the chassis plate so it doesn't get in the way when you tighten the nuts.
And with all that, I still get a bit of transformer noise, but I've convinced myself it would have been worse without the extra steps. Yup ... that's my story, and I'm stickin' with it!
MontanaWay wrote:if only we could levitate transformers....hhhmmmmm...super conductor??
corndog71 wrote:MontanaWay wrote:if only we could levitate transformers....hhhmmmmm...super conductor??
Or just levitate the whole amp. Of course, it's gonna cost ya.
https://www.gcaudio.com/cgi-bin/store/showProduct.cgi?id=247
Captain Coconut wrote:I used some grommets I had kicking around. There's more of a buzz than a hum now.
Bob Latino wrote:Just one other note ... Those 00 flat plumbing washers are made of "neoprene" which is a synthetic rubber and is much more heat resistant than regular rubber. Neoprene will take up to 200 degrees Fahrenheit without degradation of its physical characteristics. The power transformer can get up to 120+ degrees. The washers are unaffected by the heat from the power transformer.
MontanaWay wrote:Bob Latino wrote:Just one other note ... Those 00 flat plumbing washers are made of "neoprene" which is a synthetic rubber and is much more heat resistant than regular rubber. Neoprene will take up to 200 degrees Fahrenheit without degradation of its physical characteristics. The power transformer can get up to 120+ degrees. The washers are unaffected by the heat from the power transformer.
I guess I could always cut up my old neoprene diving suit.......
tubes4hifi wrote:aren't you guys still having transformer contact the chassis when using these thin rubber washers?
I use 1/8" sorbothane under the transformers, and then use the neoprene washers.
Sometimes easier to find (or maybe the same) are fiber (fibre) washers, made of a semi-hard material, like dense cardboard,
usually easy to find in any hardware store. Lots of sorbothane on ebay.
Cut one of these in 4 pieces for your transformers
http://www.ebay.com/itm/Sorbothane-SHEET-6X6x1-8IN-VIBRATION-ISOLATION-RUBBER-PAD-150MM-SQUAREx3-2-70D-/370764126470?pt=LH_DefaultDomain_0&hash=item5653439906
Just turn the sucker up loud enough and the music will drown out the mechanical hum. HmmmmmMontanaWay wrote:tubes4hifi wrote:aren't you guys still having transformer contact the chassis when using these thin rubber washers?
if as a previous post suggested, you use a beveled washer on the bottom/inside the chassis, flat washer on top of the chassis, that pretty much isolates the transformer from the chassis. Once you tighten the nut, the beveled washer gets squeezed up through the chassis hole and makes contact with the top washer. I would also use a washer under the beveled washer so that the nut does not damage it.
