    Mk4 VTA board.....270k or 220k to bias?
    Pooch
    Post by Pooch on Fri Dec 04, 2009 6:00 pm
    On my Mk 4 VTA instructions I have a diagram and showing 220k ohm to the bias, but in the instructions/ schematic it says 270K? The parts kit I got had 4 220k and I'm sure that's what's supposed to go in there, but curious, why the switch?
    Gord
    220K resistors instead of 270K
    Post by tubes4hifi on Sat Dec 05, 2009 3:41 am
    Hi Gord,
    I started switching to 220K resistors in that position about a month ago. It's not a critical value, and with some of the crappy tubes on the modern market, it reduces the chance of bias floating away from the correct setting, think of them like pull-down resistors in a semi-conductor circuit, the lower value gives a little more stability.
    Amps using KT88s rather than EL34 usually use 180K or even 150K.
    I'll update the parts list, but I probably marked your parts list when I checked it off showing the change to 220K, even though it's not that way on the schematic.
    Roy www.tubes4hifi.com
      Current date/time is Sat Jan 20, 2018 7:27 am
