    SP9 / PH10 custom build
    SP9 / PH10 custom build Empty SP9 / PH10 custom build
    Post by Guest on Thu Apr 03, 2014 12:21 am
    Just a quick few photo's of my 'never ending' SP9 build, finally seeing the light at the end of the tunnel and it aint a train!!
    Just waiting for the transformer now, then fire her up!
    The transformer in the photo is just there for show.
    SP9 / PH10 custom build Empty Re: SP9 / PH10 custom build
    Post by peterh on Thu Apr 03, 2014 1:43 am
    You forgot the IEC well ...
    Post by deepee99 on Thu Apr 03, 2014 10:38 am
    Sweet!
    Post by sKiZo on Thu Apr 03, 2014 1:24 pm
    Very tidy and clean design ... I especially like the corner splines on the case, and the satin black is a real nice touch. Bonus points if it works!
    Is that the Mogami cable you used for the inputs? I got some but ended up sticking with twisted wire for my ST120 build ...
    Oh. And you forgot the IEC well ...  pirat
    Post by Guest on Sun Apr 06, 2014 3:44 pm
    thanks people. I opted out of the IEC due to space constrains, probably could have gone with it, will see.
    Yes, it is Mogami, just made the wiring so much easier.
    The transformer arrived whilst we were away for a few days, so it will go in this afternoon and fire it up!
    Post by deepee99 on Sun Apr 06, 2014 4:13 pm
    MontanaWay wrote:thanks people. I opted out of the IEC due to space constrains, probably could have gone with it, will see.
    I have alerted the Wallace Volunteer Fire Department; they are on standby.
    Post by Guest on Sun Apr 06, 2014 4:42 pm
    gee...thanks for the vote of confidence!  Shocked
    Post by deepee99 on Sun Apr 06, 2014 4:46 pm
    Well, the woods in the Bitterroots are still pretty damp, but ya cain't never be too sure.
    I had a fire extinguisher right next to me when I lit up my M-125s.
    Keep us posted. Anxious to hear of your impending delight.
    -d-
    Post by sKiZo on Sun Apr 06, 2014 4:56 pm
    Well now, that could have gone better ...
    SP9 / PH10 custom build Firewalk
    Post by deepee99 on Sun Apr 06, 2014 4:58 pm
    sKiZo wrote:Well now, that could have gone better ...
    Or as the Aussies would say, "No worries, mate."
    colin86325
    Post by colin86325 on Sun Apr 06, 2014 7:19 pm
    Wow, she's a beauty Montana! Nicely done. Hope she sounds so sweet!
    SP9 / PH10 custom build Empty Animals fear light-up of Montana Way's amp
    Post by deepee99 on Sun Apr 06, 2014 9:57 pm
    Large mushroom spotted just now from our lookouts in Lookout Pass on the Idaho-Montana border. Trust these events are not connected with the ignition of an SP-9.
    http://rt.com/usa/epoch-bison-yellowstone-volcano-909/
    Post by Guest on Sun Apr 06, 2014 10:07 pm
    weeeeelllllll...hate to admit it, but I did screw up the transformer wiring, almost double the output voltage than what it should be....not the toroid but a 'standard' transformer.....result, no mushroom cloud, but blown voltage reg & power transistor. Replacement components are coming.
    If I had brains it would be dangerous!.....D'OH!!!!!!!!!
    Post by deepee99 on Sun Apr 06, 2014 10:13 pm
    MontanaWay wrote:weeeeelllllll...hate to admit it, but I did screw up the transformer wiring, almost double the output voltage than what it should be....not the toroid but a 'standard' transformer.....result, no mushroom cloud, but blown voltage reg & power transistor. Replacement components are coming.
    I will tell the elk and buffalo it's OK to go back to Montana, then. They're messing up our newly-paved streets.
    Post by Guest on Sun Apr 06, 2014 10:14 pm
    deepee99 wrote:Large mushroom spotted just now from our lookouts in Lookout Pass on the Idaho-Montana border. Trust these events are not connected with the ignition of an SP-9.
    on a completely different note though...that link you provided, the so called mass exodus of animals from Yellowstone Park...lets be realistic, if that super volcano does decide to blow, we'll be dust in a few minutes and so will everyone else within a couple of hundred miles...so why worry!!....I'd rather go out with the first bang than be left behind and fight over scraps of food and whatnot!.....the northern hemisphere will be pretty well screwed, followed by the rest of the planet not so long after!
    Post by Guest on Sun Apr 06, 2014 10:15 pm
     Smile
    Post by Guest on Sun Apr 06, 2014 10:27 pm
    colin86325 wrote:Wow, she's a beauty Montana! Nicely done.  Hope she sounds so sweet!
    thank you!
    Post by Guest on Thu Apr 10, 2014 12:51 pm
    well I'm hoping that the replacement voltage reg and power transistor arrive today, so that I can finally get the SP9 up and running and connected to my system!
    And yes, I have changed the transformer wiring so now I will get about 260VAC......and not close to 600VAC!!??!!.....what a Schmuck!!
    Post by Guest on Thu Apr 10, 2014 7:43 pm
    NUMBER 5 IS ALIVE!!!!!!!!....there was a movie about that.....
    Well its working, sounds great, no hum, Bass & Treble work really good, even did not mix up the left & right channels!!!
    One thing I did notice, when turning the preamp off, with power amp still on and volume about half way, you can hear a hum start up, split second, then fading away as the preamp 'winds' down, any thoughts?
    I still have the temp attenuator wired up to the ST70, I will remove that tomorrow.
    Post by Guest on Thu Apr 10, 2014 7:52 pm
    deepee99 wrote:
    MontanaWay wrote:NUMBER 5 IS ALIVE!!!!!!!!....there was a movie about that.....
    Put an itty-bitty cap across your on-off switch.
    might be a wee bit of a problem, as I am only switching 'hot'.......might have to switch both, swap over to a DPDT switch.....then I can put a cap across it....
    Post by corndog71 on Thu Apr 10, 2014 8:02 pm
    Better yet, turn your amp off first.
    Post by deepee99 on Thu Apr 10, 2014 8:22 pm
    corndog71 wrote:Better yet, turn your amp off first.
    Yep. Sequence is, preamps on for a bit, then light the after-burners. Opposite sequence shutting down: amps first, then preamps. No thumps.
    Post by Guest on Thu Apr 10, 2014 8:36 pm
    yeah, I shall do that, in any case, I swapped over switches, no switching both L & N with cap across  Very Happy.....thanks for the advise!
    Post by sKiZo on Thu Apr 10, 2014 8:41 pm
    I get something similar using my Sansui x001 receiver as a preamp. Not sure if it's that or the DAC, but it's just a momentary buzz and then it goes quiet. No evidence of said noise during playback. Wonder if it's just the nature of the beast as the tubes look for a signal they've been getting and all of a sudden aren't. Doesn't happen all the time. I'm also thinking it could be my dbx BoomBox needs a recap. Switching that out kills the noise too.
    Great job BTW ... the best part of any build is firing it up without, like ... firing it up ...
    Post by Guest on Thu Apr 10, 2014 9:09 pm
    so here is my current setup....for now  Wink
    SP9 / PH10 custom build Stereo_zpsaeced6ac
      Current date/time is Thu Jan 23, 2020 5:39 am
