    Who sells low voltage caps?
    guentherj2
    guentherj2
    Who sells low voltage caps? Empty Who sells low voltage caps?
    Post by guentherj2 on Tue Apr 08, 2014 5:55 pm
    Greetings.
    I'm looking for caps for my old Fisher XP66 speaker crossovers. Does anyone know who sells 25V caps ranging from 12 to 100 uf?
    Who sells low voltage caps? Empty Re: Who sells low voltage caps?
    Post by Guest on Tue Apr 08, 2014 6:11 pm
    have you tried Mouser?
    guentherj2
    guentherj2
    Post by guentherj2 on Tue Apr 08, 2014 6:36 pm
    Yes with no luck.
    Post by corndog71 on Tue Apr 08, 2014 7:21 pm
    I recommend ERSE caps. It's ok if the voltage ratings are bigger. In speaker crossovers stick to film caps. No electrolytic caps as they will not sound as good.
    http://www.erseaudio.com/Products/PulseX
    DarthBubba
    Post by DarthBubba on Tue Apr 08, 2014 10:29 pm
    guentherj2 wrote:Greetings.
    Not LOW voltage, not Dueland PIO Copper/Silver/Gold/Platinum/Kryptonite foil, but 100uF! http://www.parts-express.com/dayton-audio-dmpc-100-100uf-250v-polypropylene-capacitor--027-447
    Part Express has more values besides that one, too.  I've also seen air conditioner "motor-run" caps used in that application - they're often polypropylene and up to 80 or so microfarads.
    Just some ideas.  affraid
    Post by Elrick on Tue Apr 08, 2014 10:55 pm
    Various values and voltages to choose from here: http://www.partsconnexion.com/capacitor_film_mundorf_mkp.html
    I noticed my conrad johnson PV7 is populated with this type of cap as I was inspecting the innards just now so I looked them up.
    They do have a 100uF 400V job as well.
    Pillo69
    Pillo69
    Post by Pillo69 on Wed Apr 09, 2014 7:20 pm
    I placed them at the end.
    Who sells low voltage caps? DSC_0039
    Post by corndog71 on Wed Apr 09, 2014 8:21 pm
    How do they sound?
    Post by sKiZo on Thu Apr 10, 2014 5:35 pm
    I finally bit the bullet on the Erse Pulse X metallized polypropylene for my McIntosh XR16's ...
    Who sells low voltage caps? Pulse-x-crossover-caps
    Might have to enlarge the cabinets to fit all them rascals in. Fortunately, the XR16 boards are quite large and I should be able to stack them vertically, more or less in the original positions. I DO plan to add some additional support though, as we're talking quite a bit more weight once the transplant is done.
    PS ... the "C" battery is just as a point of reference. The white caps are the same value as the biggest ones, only they're metallized polyester.
      Current date/time is Thu May 23, 2019 4:01 pm
